Browse Forums Building A New House 1 Jun 14, 2007 5:02 pm Just spoke to our builder about changing the drainage system so that the grey water joins the sewerage water somewhere other than under the slab.
Basically short of spending in excess of $8000 to get the plumbers to "redesign" the system (in other words run the pipes parallel to the edge of the slab) there is no other option. To me this seems like a scandal. The plumbers are saying that they don't want to take responsibility for the system unless they redsesign the whole greywater system. I just want to have the option to get a system in the future. What does everyone else here think? 3xb Re: Prepping for a greywater system 2Jun 14, 2007 6:04 pm That sounds crazy!
I don't think we'll do anything with greywater initially - but when greywater recycling systems get cheaper, we'll invest in one - so would definitely like to have access to the pipes later. Re: Prepping for a greywater system 3Jun 14, 2007 7:35 pm Sounds like it's in the THB !!! (Too Hard Basket)
So they have priced it so you don't make life hard for them.!!!! What is the lay of the land, (ie fall verus where the sewer mains are versus where the grey water has to fall to get it into you proposed greywater system? Where it would be. In simplistic terms, it should ba a case of a second lot of pipes for the bathrooom, shower and laundry run to a external location where you can get at them. Are you thinking you'll want to treat blackwater too? Personally i wouldn't and that should keep the costs down for you. Maybe this site will help with some info. http://www.eco-smartplumber.com.au Hope this helps Steve Re: Prepping for a greywater system 4Jun 14, 2007 10:11 pm I think 8 k is too expensive. You could request them to only place diverter (costs about 60dollars) under the sink and let one of the pipes exit the laundry from the side. in this way they do not have to make major changes to existing drainage system.
Just received quote from me3con re provision for grey water diversion in future $490! I think the breakdown would be $150 for materials and $300 for labour and variation fee.As I understand, they will be providing a small exit from the side of the laundry in addition to main sewer discharge under the trough.. Initially I thought of using shower and washbasin water for flushing too but Aqua reviva costs 13K and I have heard that water can go 'off' smelling like rotten eggs. I have hence opted for flushmiser for toilets using rainwater(3.5K from builder) Laundry greywater for front garden-- ecodiverter or some such thing 3k... later on adding rainwater tanks for vegie garden 1-2 K. try requesting them again. cheers, vp Re: Prepping for a greywater system 5Jun 14, 2007 10:54 pm As stated the important thing is the ability to add it in the future. When a slab is poored, they leave a trough the size of a milk crate under the shower and bath to allow for the connections to be put it, then they fill it in. If you can get a pipe put in from that outlet to external, that would be great. I think someone actually mentioned in another thread. Adrian B Re: Prepping for a greywater system 6Jun 15, 2007 1:17 pm ![]() As stated the important thing is the ability to add it in the future. When a slab is poored, they leave a trough the size of a milk crate under the shower and bath to allow for the connections to be put it, then they fill it in. If you can get a pipe put in from that outlet to external, that would be great. I think someone actually mentioned in another thread. Hmmm. that may be the way to go, add in a pipe that doesn't connect to anything but runs to the edge of the slab. Later I can get the plumbing both internal and external. it is not the ideal solution but seems the best option I have. ![]() Mod / Remover of the spam, keeper of the forum, protector of the smiley faces waver of the big stick . And occasionally victim of us moderator police. ![]() Re: Prepping for a greywater system 7Jun 15, 2007 1:54 pm ![]() ![]() As stated the important thing is the ability to add it in the future. When a slab is poored, they leave a trough the size of a milk crate under the shower and bath to allow for the connections to be put it, then they fill it in. If you can get a pipe put in from that outlet to external, that would be great. I think someone actually mentioned in another thread. Hmmm. that may be the way to go, add in a pipe that doesn't connect to anything but runs to the edge of the slab. Later I can get the plumbing both internal and external. it is not the ideal solution but seems the best option I have. ![]() Mod / Remover of the spam, keeper of the forum, protector of the smiley faces waver of the big stick . And occasionally victim of us moderator police. ![]() If I can find a picutre, I will post it, it will explain my strange statement. Adrian B Re: Prepping for a greywater system 8Jun 15, 2007 3:16 pm Adrian, you've built with Metrikon too. Did you get the pipes laid the way you're suggesting? I received negative replies twice, finally I had to ask them to put the diverter and then they agreed.I still havent got a reply whether they will place rainwater inlet pipes for laundry.
i would like to know how you negotiated with them for these variations. cheers, vp Re: Prepping for a greywater system 10Jun 26, 2007 3:24 pm How did you end up with your grey water?
Lots of plumbers and builders still think its too hard - and it is I guess until you know how it probably is I'll show you how to keep your new home betwen 15 and 26 degrees celcius all year round - in your buget - GUARANTEED! www.sunrisehomes.net.au Forgetting about the size for now, a detention tank is applicable to a Premissable Site Discharge (PSD) flow rate, the very reason for their requirement. Check with the… 6 2640 ![]() Even with the added rigmarole, they are charging for 30 hours work at $120 hr but there isn't 30 hours work in what is described. Hydraulic engineers in general earn… 7 4722 ![]() 0 2180 |
