Browse Forums Building A New House Re: For those who built with Jarrah Boral bricks 2Sep 15, 2009 1:36 pm white ..... and white Cheers Cozmo ______________________________ Building a PD Heywood 29 http://fromevetoeternity.blogspot.com/ Re: For those who built with Jarrah Boral bricks 3Sep 15, 2009 3:48 pm We went with off-white mortar (the whitest we could get). We saw a few houses that were already built with Jarrah that had both a light mortar and a dark mortar. The houses with light mortar looked much better. It gives the bricks a nice, defined, stand-out, wow look. Where as the houses with dark mortar just made the bricks look pretty standard and average. - That's what we thought anyway. We also chose light window frames to match. Re: For those who built with Jarrah Boral bricks 4Sep 15, 2009 4:36 pm Cozmo white ..... and white Thanks for that Do you remember what the exact name of the window white you used? Was it Surfmist? Re: For those who built with Jarrah Boral bricks 5Sep 15, 2009 4:36 pm elt&kris We went with off-white mortar (the whitest we could get). We saw a few houses that were already built with Jarrah that had both a light mortar and a dark mortar. The houses with light mortar looked much better. It gives the bricks a nice, defined, stand-out, wow look. Where as the houses with dark mortar just made the bricks look pretty standard and average. - That's what we thought anyway. We also chose light window frames to match. Again, do you remember the exact name of your window colour? Which one of the following is it closest to: http://www.stegbar.com.au/products/wind ... our_chart/ Re: For those who built with Jarrah Boral bricks 6Sep 15, 2009 4:39 pm elt&kris We went with off-white mortar (the whitest we could get). We saw a few houses that were already built with Jarrah that had both a light mortar and a dark mortar. The houses with light mortar looked much better. It gives the bricks a nice, defined, stand-out, wow look. Where as the houses with dark mortar just made the bricks look pretty standard and average. - That's what we thought anyway. We also chose light window frames to match. I hope you don't mind me posting your images below (from your blog). The mortar lines look a bit uneven, and as if they are covering a bit of the brick face, or is that just because of the angle the pictures are taken? http://2.bp.blogspot.com/_7ufhsRSB_gI/S ... 009427.jpg http://3.bp.blogspot.com/_7ufhsRSB_gI/S ... 009398.jpg Re: For those who built with Jarrah Boral bricks 7Sep 15, 2009 9:27 pm getting there the examples you have posted are an example of very good work. The reason for the mortor on the brick may be due to the type of rod they have used. I was only recently talking to a brick layer about this and apparently the new plastic rods do this.
If you dont like this look you are best to find a brick layer that uses a rubber hose to joint his brick work. The result is a morter line that is softer and is customised to each brick. Re: For those who built with Jarrah Boral bricks 8Sep 16, 2009 10:31 am borg getting there the examples you have posted are an example of very good work. The reason for the mortor on the brick may be due to the type of rod they have used. I was only recently talking to a break layer about this and apparently the new plastic rods do this. If you dont like this look you are best to find a brick layer that uses a rubber hose to joint his brick work. The result is a morter line that is softer and is customised to each brick. Thanks so much for that. Will check with my brikkie. https://form.jotform.com/240284569218058 Please spare a moment to fill out this survey form for a project. You stand a chance to win a digital gift voucher. Legitimate… 0 2820 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12742 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4193 |
