Browse Forums Building A New House 1 Sep 12, 2009 4:47 pm Is it okay to mount the hot water service on a mound of clay? Our plumbers have dug up a big pile of clay about 50cm high, put a square of something on top and then sat the hot water service on top-looks very *******. I questioned them and they said it had to sit a certain height. It is a chromagen solar hot water system. Re: Is it okay to sit the hot water service on a mound of clay? 2Sep 12, 2009 9:59 pm Hardly sounds correct. i would imagine that you have a contract and it calls for standards of workmanship, a moun of clay certainly doesn't sould like proper workmanship. I checked the Chromagen manual and it says that it must be installed on an approved base. A concrete tile atop a mound of clay hardly sounds like it would fit the bill. I would check with Chromagen and see what they say and then go back to the builder and have a site meeting to discuss the quality of the installation and how the mound of clay has to last 7 years for the warranty to be valid. Dan I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3322 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 |
