Browse Forums Building A New House Re: Henley Flooring Promotion 14Jan 22, 2010 3:50 pm hmmm I'm no expert but I thought laminate flooring and engineered floorboards mean the same thing, i.e. man-made/fabricated timber-look on the top-most layer? I have spotted gum floorboards for the common areas bar wet areas and carpets for all rooms. Paid $120 per sq meter for spotted gum floorboards with underlay installed. Love the exotic colours and the high janka index for spotted gum. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10529 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6208 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 |
