Browse Forums Building A New House Re: Telephone pre-wire??? 3Sep 08, 2009 9:45 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Telephone pre-wire??? 6Sep 10, 2009 4:41 pm alk You're best off booking a time with Telstra for them to lay the cable when the services trench to your house is open. $299 for a new phone connection and they will also run a cable/point to your first front room. lol good luck on them coming out then........ most sparkies when doing the mains feed will run the telco conduit for a extra dosh, as it has to be next to the mains box anyways.. most do this already.... thank their bleesed souls.... You can (ring dial before you dig like a week before so you can get the plans sent to you) dig the 400mm deep by 200mm wide trench put in the "Telstra" approved 20mm white conduit<from Sparkie whole salers in 3m lengths plus you will need at least 1 x 90* sweep aswell (water proofed and nylon pull string inserted with 300mm+ out each above ground level, back fill 100mm of soil then place the telcoms warning tape above it then back fill the rest) for them. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16275 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13752 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8706 |
