Browse Forums Building A New House 1 Sep 02, 2009 2:25 pm Me and my hubby went and had a look at our block on the weekend and I just realized that there is a septic tank thats going to be in the middle of our driveway, I contacted Scott park and I just got email back confirming that yes its definitly going to be in our driveway and to just paint the LID. Im so F'n annoyed. Cant slip the driveway on the other side cuz its a corner block and shire said No. Has anyone else had this problem and does it really look dread full.even painted. jaz Re: A septic tank in our driveway 2Sep 03, 2009 2:39 am if you installed the septic check with the supplier but in general septic tanks are NOT to be driven over. You might end up with your car in your septic tank ewwwww nearly all septic tank instalers will tell you this. Maybe the extra concrete in your drive makes it OK??? Re: A septic tank in our driveway 3Sep 03, 2009 1:49 pm We got a septic tank and the lid is definitley not to be driven over unless you made special arrangements with the factory and payed extra money for it. I think it can have 500 kg if you didn't, but that is it. If you really don't want it I would tell the builder and not just ask. It is your land and your money and you don't want the tank there. Even when it has gone through Council and everything you can change things if you insist. Be firm. Good luck Thanks for letting us know. The programmer will have a look at this later today. 2 6690 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17539 |
