Browse Forums Building A New House 1 Jun 06, 2007 5:08 pm Hi,
I am building a house and have an additonal 1.5m added to the width of the double garage (to accomodate for the back verandah). I now have the option of centering the garage door, or keeping it off center so that I will maintain the additional 1.5m for storage space. I think the addtional storage space would be great, but from the front a centered door would look better. Does anyone have any thoughts on these options? Thanks... Re: Garage Door Position 2Jun 06, 2007 5:15 pm Re: Garage Door Position 3Jun 06, 2007 5:19 pm I would think it would look terribly asymetrical if you off centred it unless you put sometihng in the centre of the remaining area, like a window (though for some reason I have an uneasy feeling about security and a window in the front of my garage.
edit - beaten above ^^ Re: Garage Door Position 4Jun 06, 2007 5:26 pm If the window option isn't your thing then maybe you could just put some kind of largish plant or pot plant to balance it out?!
Then again if you had the garage door centred the free space on either side would be around the 750mm mark. And to me that's quite sufficient for storing stuff. Although it would then depend on what you plan to store. [sneakersss] Re: Garage Door Position 6Jun 06, 2007 6:22 pm Yeah I was thinking of putting some sort of plant or something infront of the larger wall.
I was planning on putting as much in there as possible. Im not really keen on getting a shed in the backyard, so I think I'd probably need the 1.5m....but I do think the centered door would look better. Re: Garage Door Position 7Jun 06, 2007 6:34 pm What about something like glass bricks or something you can't see through but can still let in some light to brighten up the garage area?
Cheers Allan http://building-our-first-house.blogspot.com/ Re: Garage Door Position 8Jun 06, 2007 6:37 pm One other option, make your garage doors wider. I heard B&D doors sales said that they can make any size of doors from 3 to 6 or 7 M wide.
Is yours 2 x single doors or 1 x double door? Cheers Allan http://building-our-first-house.blogspot.com/ Re: Garage Door Position 12Jun 06, 2007 7:23 pm I'd go the window option to let some natural light into the garage. Re: Garage Door Position 13Jun 06, 2007 10:28 pm ![]() Thats a possibility. Currently Its just one double door. Don't forget that to change to 2 single doors, you will need another door opener + power point + brick post in the middle, $$$$..... ![]() Would a larger door be too large and take some of the focus away from the other parts of the front of the house? I am not that good at this kind of things... Two things to consider: colour and pattern (on the door). Have a chat with the builder's colour consultant they should be able ro provide some advice. Cheers Allan http://building-our-first-house.blogspot.com/ Re: Garage Door Position 19Jun 07, 2007 11:35 am it seems to be common around where im building to just widen it out with wall and no window. (most of the time taking it to parapet) At our place thats what we have done, but we have only added about a metre.
One trick is to drop the wall back, on the bit you want to widen, so that visually it breaks up a long extended wall (hope that makes sense). Like what the footings show in the piccy below. (next doors garage) There is a place nearby that has added maybe 2.5m or so and they put a window in. Looks ok too. Also, mind that a fairly insulated garage will retain heat much longer out of a hot car engine, whilst this is welcome in winter, it could mean that you could only park… 3 5187 ![]() Hi. I am building a detached garage under a CDC in NSW, and will never need to park my car in there, rather I will use it as storage and working space. Are there any… 0 5201 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 2940 |
