Browse Forums Building A New House Re: NEED SOME SUGGESTIONS/OPINIONS BUILDING A HOUSE! 2Aug 12, 2009 2:08 pm Blog is now up - http://www.jbdave.blogspot.com/ Re: NEED SOME SUGGESTIONS/OPINIONS BUILDING A HOUSE! 3Aug 12, 2009 2:12 pm Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: NEED SOME SUGGESTIONS/OPINIONS BUILDING A HOUSE! 7Aug 13, 2009 10:50 am Blog: http://funmore-residence.blogspot.com/ Forum: viewtopic.php?f=31&t=21109 Construction Start - 19/09/09 Slab Poured - 21/10/09 Frame Completed - 25/11/09 Lockup - 22/12/09 Fixing - 22/02/10 Handover & Moved In 30/04/2010 Re: NEED SOME SUGGESTIONS/OPINIONS BUILDING A HOUSE! 10Aug 14, 2009 12:21 pm jbdave Not sure if there would be a difference to buying a house/land package, or the land and getting a house built by a builder. Usually the land isn't owned by the builder (the blocks are still owned by the developer and put together with a builder's house for marketing). You may not like the size or location of the block. If you do like the block on offer with the house, then there wouldn't be a problem with the house/land package. As for your loan, I would suggest visiting one of the bank sites and using a home loan repayment calculator. Take the current variable loan and add 2% to it. If you can afford the repayments it tells you, then you will be ok. If you would just be getting by at the current rates, then I would say it's too much as interest rates are bound to go up over the next couple of years. I would always allow for more then 2% of a interest rate rise... you never know what they are going to do. I would see what the repayments work out to be at 10% interest. Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7326 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13817 Hi VK, I am now retired however I have stood beside over 300 owner builders in the past 18 years that have successfully built their own homes. First of all a building… 10 22569 |
