Browse Forums Building A New House 1 Aug 10, 2009 1:47 pm Our new house is almost at lock up stage and the carpenter is happy to put in noggins (sp) for us at this stage. We've asked for noggins for our towel rails and toilet roll holders in all bathrooms and powder room. A big noggin for our wall mounted dryer. And in walk in robes so that some clothing rails/hooks can be put up for clothing/robes/jeans that are in use. Have I missed anything? Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: Noggins - where do you wish you had put them??? 3Aug 10, 2009 4:38 pm I am having extra studs put in for TV wall mounting. I wouldnt trust a noggin with the weight of a big flat screen. If anything, having the extra noggins in the area will make things more difficult. Re: Noggins - where do you wish you had put them??? 5Aug 10, 2009 7:57 pm extra towel racks projector mount from ceiling ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Noggins - where do you wish you had put them??? 6Aug 10, 2009 7:58 pm Ha Ha. What is a noggin??? I had to read it a few times to check if you were talking about your partner!! Built the Driftwood with C*ollier Homes Moved in 8 November 2009 Slowly getting organised ..... Re: Noggins - where do you wish you had put them??? 8Aug 10, 2009 9:08 pm cyclone i used ply between studs, but i OB. Thats the best option... Gives you plenty of room to make final adjustments after the sheeting goes up, and also allows you to pass cables behind it easily! Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Noggins - where do you wish you had put them??? 9Aug 11, 2009 6:26 am Do you have an pictures or artwork you know you will want hung up, and roughly where. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Noggins - where do you wish you had put them??? 11Aug 11, 2009 2:55 pm reaver Could be a silly question but are noggins just pieces of wood placed between spaces in the frame? Are noggins made up of anything else? same timber as the frame nice drillable pine... hmmmm Pine unless yu have a steel house then it is steel nogins but then it part of the wall itself and a bugger to rerto fit data cabling into..... actuallya bugger to fit cabling in regaurdless afaic Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Noggins - where do you wish you had put them??? 12Aug 19, 2009 9:38 pm Won't be long before our house is plastered, still have a couple of days but... is it too late to ask for extra noggins? Now i am worried if we haven't asked for noggins does that mean we won't be able to have towel rails or tv attached to the wall???? [i]We built in Point Cook and are loving our new house. Re: Noggins - where do you wish you had put them??? 13Aug 19, 2009 10:42 pm Get in there & do it yourselves with bits of frame ****** around your site. Just remember to nail them with the narrow faces facing up & down & the broad faces facing back & front IYKWIM. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Noggins - where do you wish you had put them??? 15Aug 20, 2009 2:23 pm reaver Any tips on how to nail them in? Skew nail? I knew I shouldn't have skipped carpentry class I screwed some extra noggings where we want to put more shelving and some heavy picture frames, I cut the pieces so they were nice and tight then drilled pilot holes diagonally at all 4 sides and started each screw, then put it in place and screwed with the drill, those noggings "ain't" going anywhere while I'm still kicking! you can use a stud finder later but make a note of where you put them, I put the ones in the garage at 2 mtr and made sure they were all perfectly straight with a spirit level, bit anal I know but "if a jobs worth doing"! Re: Noggins - where do you wish you had put them??? 16Aug 20, 2009 2:51 pm cyclone i used ply between studs, but i OB. Can you explain what you mean by that ? I'm a bit lost by the use of "ply between studs". We've just had our frames go up (studs and noggins) For the internal walls, I was thinking of pre-drilling through the noggins where I know I want to run some cable (tv, speakers etc...). I was even thinking of running some conduit (maybe some 20-30mm diameter stuff) through those pre-drilled holes so that I have something to guide my cables through.... although now that I think about it that might compromise the strength of the noggin in case anything is hung on it at a later date. Re: Noggins - where do you wish you had put them??? 17Aug 20, 2009 3:14 pm Thanks everyone for the good tips. We also put noggins where the patch panel will go and also in the loungeroom at picture rail height. Our building journey has begun: https://forum.homeone.com.au/viewtopic.php?f=31&t=23138 Brookvale 45 by Porter Davis ************** Lead me not into temptation.....I can find the way myself. Re: Noggins - where do you wish you had put them??? 18Aug 20, 2009 6:44 pm How about bathroom cabinet over basin/vanity? and at back of vanity? Skew nailing them is fine. Peter. Re: Noggins - where do you wish you had put them??? 19Aug 21, 2009 8:51 am Thanks everyone for the explanation. I haven't done it before and have no idea what the noggins should look like after it's screwed. Does anyone have pictures of what the noggins look like after installation? Would be fantastic if you could share some so we can do it over the weekend. [i]We built in Point Cook and are loving our new house. That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81884 I haven’t. But have a Lowe Design home. Not only did I find Matt Lowe patronising and a bully, but the home is NOT TO CODE. I have water coming through the bricks… 1 14374 Hi everyone. I am a single mother with little daughter, living in a small tourist town in WA Australia. I am thinking to install security screens to all the doors and… 0 24863 |
