Browse Forums Building A New House 1 Aug 08, 2009 12:37 pm Ok this might seem like a stupid question but i paid for capped water to the fridge space, when the framing of the house was done i saw that they had put it in, but since then the walls have been put up and painted, all power points etc installed and i see no water connection.. Is this normal????? Re: capped water to fridge space. 3Aug 08, 2009 1:12 pm I know that is my point, all the other plumbing in the house were poking out from the wall right away, but this isnt, and its been painted, grrr I meantioned it when i saw the walls being painted, the reply was, don't worry they know what they are doing, Hmmm well the house is almost finished few weeks to go, and no water connection YET! Re: capped water to fridge space. 4Aug 08, 2009 1:20 pm That's not normal. During frame stage, the plumber should have come in and ran it through the frame and then had a nozzle (looks just like a tap connection) out before the plaster was put in. They then put a proper tap connection on it so you can turn it on/off. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: capped water to fridge space. 5Aug 08, 2009 1:33 pm Hi again, This was the fridge space at frame stage, as you can see they added the water connection, though its pointing sideways within the wall? and now, painted walls etc and no water connection..sigh! http://i276.photobucket.com/albums/kk14/fully_sik/cappedwater.jpg Re: capped water to fridge space. 6Aug 08, 2009 1:34 pm that's ok then.. it is still there.. they will just have to cut a hole so that you can get to it.. strange that they put it pointing sideways.. but at least it takes up less room! Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2890 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7546 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9962 |
