Browse Forums Building A New House 1 Aug 04, 2009 7:54 pm hi one and all this is a silly question: what is the difference between agricutural drains and stormwater drainage? in my documents, somewhere it says agri drains, somewhere says stormwater drains, are they same? what are the purpose of them? any comments appreciated nh Re: what's the diference between agri drain and stormwater drain 3Aug 04, 2009 8:42 pm Agg pipe is slotted flexable & black Storm water pipe is rigid Where you are coming from is where you are going to... Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8454 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7928 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 |
