Browse Forums Building A New House 1 Jul 29, 2009 4:35 pm Could someone help us with discoloration of our bricks? Why is it happening and why only mostly under the windows? Seems like when it rains, the water runs down the window on the bricks. And that is the area which is getting discolored kinda yellow orangy tint. Is it permanent? Anyone had similar experience? Spoke with SS, and his response was that bricks change color due to sun and water. I was amazed as its been only there for 2 months. Dont you think it seems to early to have your house discolored, considering paying quite a bit of money for your house? Handover soon, should we accept the house as it is with discolored bricks or is there anything that we can do? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick discoloration Austral nougat 2Jul 29, 2009 5:10 pm I have the same bricks as you. Will have a look tonight, but I dont remember seeing any colour changes in mine. I do know we have some lighter and darker shades throughout, but not to the extreme that you have in the picture. Cheers Re: Brick discoloration Austral nougat 3Jul 29, 2009 5:37 pm We have Austral Nougat too and had the same thing happen, it is a result of some acid of some sort or similar. Ask your builder to put a neutralising agent on it, it worked for us and we don't have any more green spots My karma ran over your dogma Re: Brick discoloration Austral nougat 4Jul 30, 2009 9:44 am Hi guys, @ Haywgl, We will see what our SS says in regards to this once we have a walk thru. @mattdls, we also have light and dark color bricks. But we dont mind those. Its just the color thats bothering me. Re: Brick discoloration Austral nougat 5Jul 30, 2009 10:39 am They look like vanadium stains. Have a look on Austral's website about brick cleaning, scroll down to vanadium stains. Like others have said...a neutralising process can be used to get remove it. I will be using the same brick for our build. Interestingly I noticed that H3nley have recently put up a sign on their Nougat brick display stating that neutralizing charges are extra, so I guess it is a pretty common problem.
http://www.australbrick.com.au/vic/brick_manual_3_-_brick_cleaning_and_maintenance.php Re: Brick discoloration Austral nougat 6Jul 31, 2009 11:06 am Thanks heaps Trinity. We were loosing sleep over it . We looked up on the austral website as you suggested, and did find info on infact vanadium stains. Finally we have piece of mind . Now we will be taking it further with our builder & see what they offer. Re: Brick discoloration Austral nougat 8Sep 11, 2009 9:45 pm A limestone coloured house in our street is almost completely green from these brick "acids and element" staining. The midland brick and Austral website or consultants will be happy to help you bring your bricks back to the original colours! *Built with Gemmill Homes in WA* Slab - 1st June 2009 Plate Height - 17th June 2009 Lock Up - 18th August 2009 PCI - 5th October 2009 Hand Over - 15th Oct 2009 https://forum.homeone.com.au/viewtopic.php?f=31&t=20844 2 8359 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12127 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7226 |
