Browse Forums Building A New House 1 Jul 25, 2009 7:48 pm Hi all, This is our very 1st post... we are very excited!! We are building the Meridian 270 & have chosen the traditional facade.. The only problem is that we have only seen it as a sketch & thats not really helping us to choose our external colours. Would anyone have built a traditional facade with AV J & be happy to share a pic? Many thanks!! Re: AV Jennings - Traditional Facade? 2Jul 28, 2009 8:59 pm yeah i have had this issue we are building a traditional facade of a blueprint house. the good thing is it is very common amongst builders this facade. the window is a standard 3 set slider dowell you can inspect in the showroom but is so common on standard project homes. the front door is likely to be a corinthian PCL4 model (solid timber with 4 panel carves - one in each quater)- check it out on the net - its not quite what u see on the displays if thats your thing. the front 'porch' is concreted and has a single pier from ground to eave that about 330mm wide and then you have the garage and the garage door is standard to the house (its a b and d panel lift and you can pick from the diferent models but again they will have assigned a stanrd model to the house) i dont have photos yet, when you get plans or if you have plans you wil note that they note the standard models of exterior stuff on the plan hope this helps Re: AV Jennings - Traditional Facade? 3Jul 28, 2009 10:35 pm We are building a Porter Davis house with a Traditional facade, but I have no idea if it's anything like yours. Could you maybe post a pic of the sketch? Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: AV Jennings - Traditional Facade? 4Jul 28, 2009 10:37 pm Hi I am building the Coventry 33 with the traditional facade which they only had a sketch of, but changed the portico pillars to brick instead of the wood that they had. traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4224 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7554 |
