tree removal
would like to know if we need to get approval for removing tree?
Will builder get it removed or we should get a removal company to do it? will they take care everything if need permit?
How about fence as well? I heard it's a usual thing that the fence company will contact the neighbour to share for building fence, is it true? how do they find out the neighbour if it's a vacant land not yet being built.
A “significant tree” is: • any tree which has a trunk circumference of 2.0 metres or more; or • in the case of trees with multiple trunks, any tree that has trunks with a total circumference of 2.0 metres or more and an average trunk circumference of 625mm or more. In both cases, trunk circumference is measured one metre above natural ground level
We had to get the permit organised ourselves (easy). Our demolition guy contracted a tree removal service/arborist to remove them and the stumps. That cost us $900. No harm asking your builder if they will deal with it, but get your own quotes first as they will most likely add a good markup.
We had to fill out an application form, with a sketch of the site..marking what we wanted to remove + supply photos. Application was free (BCC).
Took 6 weeks for them to assess it. The came out to the site and inspected before giving approval. We were allowed to remove everything we asked for but not allowed to even prune the tree with the VPO.
Cost us under 3k to remove 10 big pines + a couple of palms with the stumps ripped out or ground + removal. Would be WAAAYYY more expensive to do after the house was there.
Hope that helps.
At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the…
3/09/2023
Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best…
27/11/2023
1
PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon
