Browse Forums Building A New House Page 1 of 1 14 replies Reply Like Share More Reply Like Share More 09 Jan 2009 3,271 VIC Gold Member Re: Practical Completion inspection 2Jul 17, 2009 4:59 pm Have a look at the last couple of pages of this thread as PCI has just been discussed. viewtopic.php?f=31&t=15119 Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Reply Reply Like Share More 23 Jan 2009 10,350 Mernda, Where my gumboots are Gold Member Re: Practical Completion inspection 3Jul 17, 2009 5:42 pm I made a list from that link: • Make sure you open and close lots of things eg all doors incl cupboards etc, • open and close all windows • check all taps and make sure the water drains away. • Check all paint work • look down the side of the walls where the light shines onto it. • Make sure all doors have the weather strips • check that the roof insulation is tidy and even. • Check for chipped bricks and discoloured or missing mortar. • Make sure there are no missing roof tiles. • Make sure the windows aren't scratched on the frame or glass. • Check that no tiles are pointing (higher than others). (bare feet) • Make sure toilets are centred in the space and flush properly. • Exhaust fans work • check under the vanities to check that when they drilled the holes to get hte plumbing through they did a good job • check the cabinetry- our upper kitchen cupboard doors are all slightly warped • check the sliding door handles are all the same styles- our weren't • check the windows to make sure they didn't get paint sprayed on them- you may need to feel for the paint as it may not show up in the light- we didn't notice ours until it was dark • check the sliding doors are level and shut properly- ours are a bit wonky • check for all the extra power points are there • Take a hair dryer to test every single power point works • Check all lights turn on • take a level to check light switches and power points 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Reply Reply Like Share More 24 Feb 2009 243 Sunshine Coast Bronze Member Re: Practical Completion inspection 4Jul 17, 2009 5:51 pm Thank you very much for your time , Lisanne. Building has not started yet but I copied your list to a Word document and will add it to the thick folder of things TO DO during the build. Very much appreciated. Reply Reply Like Share More 26 Oct 2007 578 South West WA Gold Member Re: Practical Completion inspection 5Jul 18, 2009 11:41 am If you're not normally a picky person, don't feel bad about being picky during the inspection . . . or if your partner is more picky then you then make sure they do it! If you have the opportunity see if you can have a good look through the house before the PCI, just on your own. Basically anything that doesn't seem or look right and anything that you know will bother you. Cosmetic things like gaps showing in wardrobe shelving, powerpoints not sitting flush against the wall, check around the door handles (a couple of ours had holes showing because they were drilled a bit big). Practical things, like making sure all the light switches are where they should be, lights, powerpoints, appliances working. Check that hot taps have hot water and cold taps have cold. Oh and funny enough it's easy to miss significant things like soap holders and towel rails, toilet roll holders etc, so make sure they're all there. If you miss anything don't worry because I imagine the builder will have a certain maintenance period anyway (4 months for ours) where you can get things fixed that you notice after you move in. Reply Reply Like Share More Reply Like Share More 15 Sep 2008 83 Loyal Member Re: Practical Completion inspection 7Aug 18, 2009 10:58 am Pebble If you're not normally a picky person, don't feel bad about being picky during the inspection . . . or if your partner is more picky then you then make sure they do it! Hi Pebble, Thanks for your advice, I just went through the whole PCI ordeal and it was rather stressful! I had one question, if you bring your partner to the PCI - and their name isn't on the contract. Is she allowed to walk through the house with me during the PCI? My partner came with me to attend the PCI (Two sets of eyes is better than 1 as they say) but the Site supervisor and Construction Manager said no, only the person who's name appears on the contract is allowed to walk through the PCI. This confused me to no end?! is there a ruling that states this in the contract?? I can't find it if there is..? btw, i'm building with Sim*nds... Thanks!!~ Bunky! Reply Reply Like Share More 23 Jan 2009 10,350 Mernda, Where my gumboots are Gold Member Re: Practical Completion inspection 8Aug 18, 2009 11:01 am bunky Pebble If you're not normally a picky person, don't feel bad about being picky during the inspection . . . or if your partner is more picky then you then make sure they do it! Hi Pebble, Thanks for your advice, I just went through the whole PCI ordeal and it was rather stressful! I had one question, if you bring your partner to the PCI - and their name isn't on the contract. Is she allowed to walk through the house with me during the PCI? My partner came with me to attend the PCI (Two sets of eyes is better than 1 as they say) but the Site supervisor and Construction Manager said no, only the person who's name appears on the contract is allowed to walk through the PCI. This confused me to no end?! is there a ruling that states this in the contract?? I can't find it if there is..? btw, i'm building with Sim*nds... Thanks!!~ Bunky! What a load of crap! As I was reading your post I was thinking it sounded like Sim*nds and I was right! They've done this before with other H1 members and try to pull stunts like that with independent inspectors coming through Ring the building commission and ask them 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Reply Reply Like Share More 15 Sep 2008 83 Loyal Member Re: Practical Completion inspection 9Aug 18, 2009 11:11 am lisanne What a load of crap! As I was reading your post I was thinking it sounded like Sim*nds and I was right! They've done this before with other H1 members and try to pull stunts like that with independent inspectors coming through Ring the building commission and ask them Hi Lisanne, Thanks for your reply! I had read on the forum that things like this did happen previously. But i thought that it would be fine.. i couldn't see anywhere on the contract which stipulates that the only person who can walk through the PCI is the person who's name is on the contract! I Initially wanted to get Kevin from NHI to do the PCI for me, however Sim*nds was so pushy they wanted it done that week (only giving 4 days notice i might add) that Kevin was booked out and couldn't make it, hence i had to do it myself. The good thing is (or so we thought) that we got in writing from Sim*nds that they would allow Kevin to do his report a week after the PCI and the findings would be included in the PCI. But now (even though we have it in writing) Sim*nds are disputing the fact that they will consider and act upon the findings from Kevin. *sigh*... Thanks for the advice, i'll give the Building Commission a call and see what the ruling is! Bunky! Reply Reply Like Share More 04 Mar 2007 215 Bronze Member Re: Practical Completion inspection 10Sep 02, 2009 10:04 am lisanne I made a list from that link: • look down the side of the walls where the light shines onto it. Can you please explain above 'check' a bit more please? Is it to see if the wall is flat or not? Reply Reply Like Share More 23 Jan 2009 10,350 Mernda, Where my gumboots are Gold Member Re: Practical Completion inspection 11Sep 21, 2009 9:05 am I just spent the last 20 minutes looking for this thread as my list is at home on my laptop and I wanted to print it off! Just thought I would bump this up for others to read again 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Reply Reply Like Share More 31 May 2019 1 Perth WA New Poster Re: Practical Completion inspection 12May 31, 2019 9:09 pm Here is the list what we using before PCI meeting Bedroom 1 (1) Is the 3.345 sq/m of door paint ok? (2) Margins round the door…are they consistent? (3) Do both hinges have all screws fitted? (4) Does the door latch have all screws? (5) Does the striker plate have all screws fitted? (6) Does the door have a cushion stop or catch fitted? (7) Do the architraves have sanded and closed mitres? (8) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (9) Does the door have excessive rattle when closed? (10) Does the door latch? (11) Is there more than 25mm under the door? (12) Are there any scratches to the 3.24 sq/m of window glass? (13) Is there any damage to the window framework? (14) Does the window slide freely and lock? (15) Does the window slider shut square? (16) Are the window architraves mitres tight and sanded? (17) Do window furnishings work as expected? (18) Does the light work? (19) Is there any damage to the light fitting? (20) Is the light switch and power points level and plumb? (21) Does the 41 sq /m of wall and ceiling paint have any defects? (22) Is the 12.96 sq/m of carpet installed correctly? (23) Is the carpet dirty or marked? (24) Are the cornice lines nice and straight? (25) Is the skirting nice and straight? Bedroom 2 (26) Is the 3.345 sq/m of door paint ok? (27) Margins round the door…are they consistent? (28) Do both hinges have all screws fitted? (29) Does the door latch have all screws? (30) Does the striker plate have all screws fitted? (31) Does the door have a cushion stop or catch fitted? (32) Do the architraves have sanded and closed mitres? (33) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (34) Does the door have excessive rattle when closed? (35) Does the door latch? (36) Is there more than 25mm under the door? (37) Are there any scratches to the window glass? (38) Is there any damage to the window framework? (39) Does the window slide freely and lock? (40) Does the window slider shut square? (41) Do window furnishings work as expected? (42) Are the window architraves mitres tight and sanded? (43) Does the light work? (44) Is there any damage to the light fitting? (45) Is the light switch and power point level and plumb? (46) Does the 36.128 sq /m of wall and ceiling paint have any defects? (47) Does the robe sliding doors shut square to the closing jambs? (48) Is there any damage to the robe doors? (49) Is the robe hanging rail installed? (50) Is the robe shelf installed correctly and level? (51) Is the timber under the bottom robe track painted? (52) Is the 9sq/m of carpet installed correctly? (53) Is the carpet dirty or marked? (54) Are the cornice lines nice and straight? (55) Is the skirting nice and straight? Bedroom 3 (56) Is the 3.345 sq/m of door paint ok? (57) Margins round the door…are they consistent? (58) Do both hinges have all screws fitted? (59) Does the door latch have all screws? (60) Does the striker plate have all screws fitted? (61) Does the door have a cushion stop or catch fitted? (62) Do the architraves have sanded and closed mitres? (63) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (64) Does the door have excessive rattle when closed? (65) Does the door latch? (66) Is there more than 25mm under the door? (67) Are there any scratches to the window glass? (68) Is there any damage to the window framework? (69) Does the window slide freely and lock? (70) Does the window slider shut square? (71) Do window furnishings work as expected? (72) Are the window architraves mitres tight and sanded? (73) Does the light work? (74) Is there any damage to the light fitting? (75) Is the light switch and power point level and plumb? (76) Does the 36.128 sq /m of wall and ceiling paint have any defects? (77) Does the robe sliding doors shut square to the closing jambs? (78) Is there any damage to the robe doors? Bedroom 4 (86) Is the 3.345 sq/m of door paint ok? (87) Margins round the door…are they consistent? (88) Do both hinges have all screws fitted? (89) Does the door latch have all screws? (90) Does the striker plate have all screws fitted? (91) Does the door have a cushion stop or catch fitted? (92) Do the architraves have sanded and closed mitres? (93) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (94) Does the door have excessive rattle when closed? (95) Does the door latch? (96) Is there more than 25mm under the door? (97) Are there any scratches to the window glass? (98) Is there any damage to the window framework? (99) Does the window slide freely and lock? (100) Does the window slider shut square? (101) Are the window architraves mitres tight and sanded? (102) Do window furnishings work as expected? (103) Does the light work? (104) Is there any damage to the light fitting? (105) Is the light switch and power point level and plumb? (106) Does the 36.128 sq /m of wall and ceiling paint have any defects? (107) Does the robe sliding doors shut square to the closing jambs? (108) Is there any damage to the robe doors? (109) Is the robe hanging rail installed? (110) Is the robe shelf installed correctly and level? (111) Is the timber under the bottom robe track painted? (112) Is the 9sq/m of carpet installed correctly? (113) Is the carpet dirty or marked? (114) Are the cornice lines nice and straight? (115) Is the skirting nice and straight? Toilet (116) Is the 3.345 sq/m of door paint ok? (117) Does the 15.95 sq /m of wall and ceiling paint have any defects? (118) Margins round the door…are they consistent? (119) Do both hinges have all screws fitted? (120) Does the door latch have all screws? (121) Does the striker plate have all screws fitted? (122) Does the door have lift off hinges fitted? (123) Are the lift off hinges fitted right way up and not upside down? (124) Is there enough gap at top of door to lift door off hinges? (125) Does the door have a cushion stop or catch fitted? (126) Do the architraves have sanded and closed mitres? (127) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (128) Does the door have excessive rattle when closed? (129) Does the door latch? (130) Is there more than 25mm under the door? (131) Are there any scratches to .54 sq/m of window glass? (132) Is there any damage to the window framework? (133) Does the window slide freely and lock? (134) Does the window slider shut square? (135) Do window furnishings work as expected? (136) Are the window architraves mitres tight and sanded? (137) Does the light work? (138) Is there any damage to the light fitting? (139) Is the light switch level and plumb? (140) Is there a toilet roll holder fitted? (141) Are there any chips to the 1.35 sq/ m of floor tiling or 3.9 lin/m of skirting tiles? (142) Has all tiling been done in a tradesman like manner? (143) Has all sealant been done between floor tiling and skirting tiles? (144) Does the toilet flush (145) Any leaks at toilet flush pipe? (146) Is the toilet seat loose? (147) Has toilet pan been screwed down? (148) Has toilet pan been sealed to floor? (149) Are the cornice lines nice and straight? (150) Is the skirting tiling nice and straight? Walk in Robe (151) Is the 3.345 sq/m of door paint ok? (152) Margins round the door…are they consistent? (153) Do both hinges have all screws fitted? (154) Does the door latch have all screws? (155) Does the striker plate have all screws fitted? (156) Does the door have a cushion stop or catch fitted? (157) Do the architraves have sanded and closed mitres? (158) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (159) Does the door have excessive rattle when closed? (160) Does the door latch? (161) Is there more than 25mm under the door? (162) Is the 2.25 sq/m of carpet installed correctly? (163) Does the light work? (164) Is there any damage to the light fitting? (165) Is the light switch level and plumb? (166) Does the 15sq /m of wall and ceiling paint have any defects (167) Is the 2.4 lin/m of shelving installed correctly (168) Are all hanging rails installed? Bathroom (169) Is the 3.345 sq/m of door paint ok? (170) Margins round the door…are they consistent? (171) Do both hinges have all screws fitted? (172) Does the door latch have all screws? (173) Does the striker plate have all screws fitted? (174) Does the door have a cushion stop or catch fitted? (175) Do the architraves have sanded and closed mitres? (176) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (177) Does the door have excessive rattle when closed? (178) Does the door latch? (179) Is there more than 25mm under the door? (180) Are there any scratches to the 1.44 sq/m of window glass? (181) Is there any damage to the windows framework? (182) Does the window slide freely and lock? (183) Does the window slider shut square? (184) Do window furnishings work as expected? (185) Are the window architraves mitres tight and sanded? (186) Does the light work? (187) Is there any damage to the light fitting? (188) Is the light switch and power points level and plumb? (189) Does the exhaust fan run ok? (190) Are all heat lamp globes working? (191) Do the 15 sq /m of wall and ceiling paint have any defects? (192) Is the sealant to all tiling complete? (193) Is there any chips or scratches to the 2.56 sq/m of bath surfaces (194) Does the shower screen leak? (195) Are there any blemishes to the 3.42 sq/m of glass and framework of the shower screen? (196) If the shower base is acrylic are there any scratches or chips to the .82 sq/m of surface? (197) Are there any chips to the 10.14 sq/m and 2.1lin/m of wall, floor and skirting tiling? (198) Is there any damage to the 6 tap handles, 2 spouts and 1 shower rose? (199) Any damage to the 1.45sq/m of mirror and framework. (200) Are all towel rails level? (201) Are the towel rails loose on the wall? (202) Is there any damage to the vanity’s 1.515 sq/m of surface area? (203) Are there any water leaks inside the vanity? (204) Are the cornice lines nice and straight? (205) Are the skirting tiles nice and straight? (206) Is the aluminium angle under the door threshold clean? Ensuite (207) Is the 3.345 sq/m of door paint ok? (208) Margins round the door…are they consistent? (209) Do both hinges have all screws fitted? (210) Does the door latch have all screws? (211) Does the striker plate have all screws fitted? (212) Does the door have a cushion stop or catch fitted? (213) Do the architraves have sanded and closed mitres? (214) Is there any chipped timber at the striker plate and latch that needs filling/ paint touch up? (215) Does the door have excessive rattle when closed? (216) Does the door latch? (217) Is there more than 25mm under the door? (218) Are there any scratches to the 1.44 sq/m of window glass? (219) Is there any damage to the windows framework? (220) Does the window slide freely and lock? (221) Does the window slider shut square? (222) Do window furnishings work as expected? (223) Are the window architraves mitres tight and sanded? (224) Does the light work? (225) Is there any damage to the light fitting? (226) Is the light switch and power points level and plumb? (227) Does the exhaust fan run ok? (228) Are all heat lamp globes working? (229) Do the 15 sq /m of wall and ceiling paint have any defects? (230) Is the sealant to all tiling complete? (231) Is there any chips or scratches to the 2.56 sq/m of bath surfaces (232) Does the shower screen leak? (233) Are there any blemishes to the 3.42 sq/m of glass and framework of the shower screen? (234) If the shower base is acrylic are there any scratches or chips to the .82 sq/m of surface? (235) Are there any chips to the 10.14 sq/m and 2.1lin/m of wall, floor and skirting tiling? (236) Is there any damage to the 4 tap handles, 1 spouts and 1 shower rose? (237) Any damage to the 1.45sq/m of mirror and framework. (238) Are all towel rails level? (239) Are the towel rails loose on the wall? (240) Is there any damage to the vanity’s 1.515 sq/m of surface area? (241) Are there any water leaks inside the vanity? (242) Are the cornice lines nice and straight? (243) Are the skirting tiles nice and straight?+ (244) Is the aluminium angle under the door threshold clean? Entry (245) Is the 3.345 sq/m of door paint ok? (246) Margins round the door…are they consistent? (247) Do both hinges have all screws fitted? (248) Does the door latch have all screws? (249) Does the striker plate have all screws fitted? (250) Does the door have a cushion stop or catch fitted? (251) Do the architraves have sanded and closed mitres? (252) Is there any chipped timber at the framework, striker plate and latch that needs Filling/ paint touch ups? (253) If there is a barrier/security door fitted does this operate as it should? (254) Does the 12 sq /m of wall and ceiling paint have any defects? (255) Does the 3.6 sq/m of floor tiles have any chips or damage etc.? (256) Is the sealant to all tiling complete? (257) Does the light work? (258) Is the light switch plumb? (259) Does the door latch? (260) Does the door have excessive rattle when closed? Garage (261) Is the 6.7sq/m of door paint ok? (262) Margins round the doors…are they consistent? (263) Do the 4 hinges have all screws fitted? (264) Does the door latches have all screws? (265) Do the striker plates have all screws fitted? (266) Does the doors have a cushion stop or catch fitted? (267) Do the architraves have sanded and closed mitres? (268) Is there any chipped timber at the framework, striker plate and latch that needs filling/ paint touch ups? (269) If there is a barrier/security door fitted does this operate as it should? (270) Do the 96.8 sq /m of wall and ceiling paint have any defects? (271) Does the 36 sq/m of concrete floor have any chips or damage etc.? (272) Does the light work? (273) Is the light switch plumb? (274) Do the doors latch? (275) Does the doors have excessive rattle when closed? (276) Does the panelift/ roll-a-door work as expected? (277) Any damage to the panelift/roll-a-door? Lounge (278) Are there any scratches to the 3.24 sq/m of window glass? (279) Is there any damage to the windows framework? (280) Does the window slide freely and lock? (281) Does the window slider shut square? (282) Are the window architraves mitres tight and sanded? (283) Do window furnishings work as expected? (284) Does the light work? (285) Is there any damage to the light fitting? (286) Is the light switch and power points level and plumb? (287) Do the 41 sq /m of wall and ceiling paint have any defects? (288) Is the 12.96 sq/m of carpet installed correctly? (289) Is the carpet dirty or marked? (290) Are the cornice lines nice and straight? (291) Is the skirting nice and straight? Hallway (292) Do the 58.8sq /m of wall and ceiling paint have any defects? (293) Is the 16.8sq/m of tiling chipped or damaged? (294) Is the tiling dirty or marked? (295) Are the cornice lines nice and straight? (296) Is the skirting nice and straight? (297) Is the 6.o lin/m of linen cupboard shelving installed and painted correctly? (298) Is the 6.7sq/m of door paint ok? (299) Margins round the doors…are they consistent? (300) Do the 4 hinges have all screws fitted? (301) Does the door latches have all screws? (302) Do the striker plates have all screws fitted? (303) Does the door have a cushion stop or catch fitted? (304) Do the architraves have sanded and closed mitres? (305) Is there any chipped timber at the framework, striker plate and latch that needs filling/ paint touch ups? Meals / Family (306) Are there any scratches to the 12.91 sq/m of window/sliding door glass? (307) Is there any damage to the window framework? (308) Do the windows and sliding door slide freely and lock? (309) Does the window sliders shut square? (310) Are the window architraves mitres tight and sanded? (311) Do window furnishings work as expected? (312) Do all the lights work? (313) Is there any damage to the light fittings? (314) Is the light switch and power points level and plumb? (315) Do the 58.8sq /m of wall and ceiling paint have any defects? (316) Is the 30sq/m of tiling chipped or damaged? (317) Is the tiling dirty or marked? (318) Are the cornice lines nice and straight? (319) Is the skirting nice and straight? Kitchen (320) Are there any scratches to the 1.08sq/m of window glass? (321) Is there any damage to the window framework? (322) Does the window slide freely and lock? (323) Does the window sliders shut square? (324) Are the window architraves mitres tight and sanded? (325) Do window furnishings work as expected? (326) Do all the lights work? (327) Is there any damage to the light fittings? (328) Is the light switch and power points level and plumb? (329) Does the 14.8sq /m of wall and ceiling paint have any defects? (330) Is the 5.18sq/m of floor tiling chipped or damaged? (331) Is the tiling dirty or marked? (332) Are the cornice lines nice and straight? (333) Is the skirting nice and straight? (334) Is there any damage to the 31sq/m of benchtop, cupboard doors and internal linings of all the joinery? (335) Is the 18 cupboard door and draw handles level (336) Is there any damage to the .78sq/m of kitchen sink? (337) Are there any water leaks under the kitchen sink? (338) Has all the joinery been sealed to the wall? (339) Has the splashback been sealed to the joinery? (340) Is there any damage to the 1.44sq/m of splashback tiling or glass (341) Are all white goods installed? Exterior (342) Is there any damage to the 117.04 sq/m of bricks ( app 6,800 bricks) (343) Do all the mortar beds and perps look consistent? (344) Is there any damage to the 16 windows, sliding doors and door framework? (345) Do all the brick sills look consistent? (346) Do the brick sills have a gap between the window framework (347) Are all articulated joints filled? (348) Is the eaves line straight? (349) Are there any loose bricks at the tops of windows? (350) Does the 62 lin/m or 37.2 sq/m of soffit have good paint coverage (351) Is the 62lin/m of fascia and gutter straight (352) Does the 62 lin/m of fascia and gutter have any damage (353) Are there any loose gutter brackets that can be seen from the ground? (354) Are the 7 downpipes all hooked up? (355) Is there any damage to the 7 downpipes? (356) Can you see any damage or dents to the 247.5sq/m of metal or tile roof? (357) Is the roof completely finished? (358) Are all vent cowls on? (359) Is the 84 lin/m of fencing straight? (360) Do any of the 840 pailings need replacing? (361) Do the side gates work? (362) Is the 38sq/m of driveway damaged? (363) Is there damage to the 30sq/m of patio, paths or porch concrete? (364) Is the landscaping complete? (365) Is the letterbox in? (366) Is the TV antenna in? (367) Is the clothes line in? (368) Is the hot water unit installed? (369) Are there any areas of turf that need replacing? (370) Is there any damaged garden edging? (371) Are there any weeds to be removed? (372) Is the external plumbing complete? (373) Has all the expansion foam been trimmed at paths and driveways? (374) Is there any building material or rubbish still to remove? (375) Has the house had a final clean? Items a builder doesn’t have to do… (376) Does not have to seal the main floor tiling to skirting (377) Does not have to fit cushion bumps to robe doors (378) Does not have to fit clear bumps to cupboard, vanity or pantry doors that hit the walls (379) Does not have to fit clear bumps to shower doors that hit towel rails or toilets. (380) Does not have to do an “owners clean” once the job is finished. (381) Only has to do a site clean, not landscaping if it is a house only contract and not a “turn key”. (382) Only has to remove “spoil” if it is in the contract. Quality is our priority... Reply Reply Like Share More 24 Mar 2019 103 Caboolture QLD Senior Member Re: Practical Completion inspection 13Jul 14, 2019 7:34 pm Hey, so I have my PCI on the 23rd and have found this checklist very helpful. Has anyone pulled the builder up on the condition of the Slab? For example: the painters were very messy and didn’t protect the slab when painting. In particular, I am wondering if I can ask the site supervisor to have the slab cleaned. The garage floor has been discoloured by paint and there’s a considerable amount of spilt (chunky in areas) paint on the floor in the media room. We have flooring going down in the media however the garage was just plain concrete and this looks totally horrible. Has anyone else had an issue with this? Reply Reply Like Share More 09 Sep 2019 98 QLD Loyal Member Re: Practical Completion inspection 14Mar 27, 2020 1:43 pm NathanRetreat298 Hey, so I have my PCI on the 23rd and have found this checklist very helpful. Has anyone pulled the builder up on the condition of the Slab? For example: the painters were very messy and didn’t protect the slab when painting. In particular, I am wondering if I can ask the site supervisor to have the slab cleaned. The garage floor has been discoloured by paint and there’s a considerable amount of spilt (chunky in areas) paint on the floor in the media room. We have flooring going down in the media however the garage was just plain concrete and this looks totally horrible. Has anyone else had an issue with this? How did you go with that Nathan? We have silicone/brown stuff on our beautiful light bricks outside the kitchen window. We aren't having flooring in 2 rooms and they've covered them in paint. Our rear patio has what looks to be concrete and grout spilt all over it and again we are having plain concrete. I'm a bit concerned about how this will go down Follow our build - https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Reply Reply Like Share More 16 Mar 2012 3,535 Melbourne Victoria, " Frogmouth Cottage" Primrose Sands Tasmania Re: Practical Completion inspection 15Mar 29, 2020 1:11 pm Vanessa you are typical example of diy homeowner who decided not to employ independent private inspector, presumably to save $650 but instead you will be underwriting your own risk. If things go pear shaped it may cost you a lot more, perhaps crippling your investment. Sure you got Roscon list that will help you pick up a lot of fleas but you may miss elephants. Why? because you don't know what to look for. Elephants missing on Roscon list
There is no substitute for experienced independent building consultant look over your build. Good luck Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Reply Sign in or Join to reply to this Topic End
Page 1 of 1 ⋅ 15 posts
Related RelatedBuilding A New House Builder not giving letter of commencement and practical compBuilder not giving letter of commencement and practical comp The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6256 Watch late completion penaltylate completion penalty Like I said the Occupancy Certificate is not the tollgate that marks the completion of the house. The contract defines… 7 10809 Watch What's unreasonable to check during a final inspection ?What's unreasonable to check during a final inspection ? i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98817 Watch Building inspection after 90 Day Defect periodBuilding inspection after 90 Day Defect period you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5457 Watch Sewer Inspection PointSewer Inspection Point Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6699 Watch |
Browsing this forum akay and 801 guests |
Australia's largest home building and renovation
community with over 1.8 million posts
