Browse Forums Building A New House 1 Jul 12, 2009 12:23 am How many people have had this problem? The first time we built, we had an extra pipe and no one knew what it was for. This time we have a pipe which has ended up under the frame??? Show and tell please. http://img21.imageshack.us/img21/101/pipejaa.jpg T. Re: PIPES IN THE WRONG PLACE IN SLAB 3Jul 12, 2009 9:36 am could be an electrical conduit... which means just a few cables come out of it.... we had a pipe in our WIR and were curious about why it was no where near where water was meant to be but in the end it is an electrical conduit which they cut off at the slab and ran a few wies through... but i would assume they didn't mean for it to be under the frame! 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Re: PIPES IN THE WRONG PLACE IN SLAB 4Jul 12, 2009 9:43 am My brothers house has one of the bathroom pipes in the hallway 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: PIPES IN THE WRONG PLACE IN SLAB 5Jul 12, 2009 10:12 am I had 3 pipes that were only slightly out of place in the slab. It's really no biggy and they can be fixed relatively easily (well, mine were!) First one was the pipe from the upstairs bathroom coming down through the walls. It was sitting in the hallway by about 4mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They cut it out and dug away part of the slab and put in an elbow join so it wasn't sticking out in the hallway! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The second one was the laundry trough waste was partway through the frame: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As it wasn't a load bearing wall, they chopped a bit out of the bottom of the frame. The third was our powder room toilet was slightly out of wack! The moved it to the correct position... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ...and then came back at a later stage to fix the 'shelf' left in it and fixed up the slab around it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also had an 'unknown' pipe, but it turned out to be under the slab access for water to the kitchen island bench. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: PIPES IN THE WRONG PLACE IN SLAB 6Jul 12, 2009 10:29 am I have a slight mis alignment here too, how much of a problem is it? 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: PIPES IN THE WRONG PLACE IN SLAB 7Jul 12, 2009 11:48 am Hi Lisa, I was more concerned with the way it looked before the final fix! There was a big 'shelf' in the pipe and I was worried things would get stuck on it and cause blockages in the future. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The final fix is fine and all should drain away nicely. If not, then they will be out to fix it! SS assures me it's fine! My parents had the same thing, and their place is now 4 years old, and absolutely no problem to date so far. There is only a toilet and vanity in the powder room, and the floor will be tiled, so hopefully, the fixed slab section won't cause too many problems either, but most of it will be covered with leveliing compound before the tiling can begin anyway... A plumber might be able to advise more, though! Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: PIPES IN THE WRONG PLACE IN SLAB 8Jul 12, 2009 5:36 pm Dear all, Thank you all for the input, it looks as though they can fix it, I am quite surprised how often it happens. Our outlet pipe is for the wash basin in the downstairs powder room and the photo shows it appearing in the laundry, it looks like they are going to have to move it right out of the way of the frame. Did you have to complain about it or did they fix it automatically? Thanks again T. Re: PIPES IN THE WRONG PLACE IN SLAB 9Jul 12, 2009 5:42 pm torourke1 Dear all, Thank you all for the input, it looks as though they can fix it, I am quite surprised how often it happens. Our outlet pipe is for the wash basin in the downstairs powder room and the photo shows it appearing in the laundry, it looks like they are going to have to move it right out of the way of the frame. Did you have to complain about it or did they fix it automatically? Thanks again T. Do you have a wall hung vanity in the powder room? Our powder room has one so the plumbing is in the wall cavity. Part of the frame is cut away around where the pipe enters the slab. Could this be a reason for the pipes appearing in the wrong place? Re: PIPES IN THE WRONG PLACE IN SLAB 11Jul 12, 2009 6:33 pm Ooops We were lucky as ours we spot on. In fact I am impressed with the positioning of the toilets as I was sure on of them would be too far out from the wall Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: PIPES IN THE WRONG PLACE IN SLAB 13Jul 13, 2009 1:10 am Hi there That's unbelievable! but, they did fix it satisfactorily. What is it plumbers can't read house plans? I didn't realise that after the concrete was poured they could just lift it and try again, I thought it was pretty much set in stone (concrete) . Did you bring it to the attention of the supervisor? T. Re: PIPES IN THE WRONG PLACE IN SLAB 14Jul 13, 2009 6:27 am torourke1 What is it plumbers can't read house plans? Ive seen the pre slab plumbing a whole 6 Metres off from where it should have been, they fixed it before the slab went down though.... 4 5121 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10827 |
