Browse Forums Building A New House Re: Final inspection tomorrow: Any tips? 2Jun 30, 2009 8:15 pm Hi,I'm still in pre-construction stage but a friend of mine who built recently advised me to(if & when my house actually gets done-yawn); *turn on every tap (run the hot taps until the water gets hot) *flush toilets 1/2 flush then full (make sure the water cuts off when the cistern is filled and no water keeps trickling out afterwards) *turn on every light switch (dont forget the outside ones,too) *bring a hair dryer with you and run it on EVERY power outlet (dont forget outside powerpoints & garage) *turn on every part of your cooktop/oven dishwasher etc *open and close every door,including robes etc *make sure the circuit breaker works *run a hose on the roof to see if the gutters drain properly and to see if the downpipes are good i think there were a few more points but i cant remember (getting a little bit blonder as i'm getting a little bit older). Anyway,I hope this helps!! Cheers, Issy Re: Final inspection tomorrow: Any tips? 3Jun 30, 2009 8:23 pm issy jo Hi,I'm still in pre-construction stage but a friend of mine who built recently advised me to(if & when my house actually gets done-yawn); *turn on every tap (run the hot taps until the water gets hot) *flush toilets 1/2 flush then full (make sure the water cuts off when the cistern is filled and no water keeps trickling out afterwards) *turn on every light switch (dont forget the outside ones,too) *bring a hair dryer with you and run it on EVERY power outlet (dont forget outside powerpoints & garage) *turn on every part of your cooktop/oven dishwasher etc *open and close every door,including robes etc *make sure the circuit breaker works *run a hose on the roof to see if the gutters drain properly and to see if the downpipes are good i think there were a few more points but i cant remember (getting a little bit blonder as i'm getting a little bit older). Anyway,I hope this helps!! Cheers, Issy Great tips Issy! along with all doors, all drawers, shower screens etc too! I also plan to check that all powerpoints and light switches are straight and level. Check all the cornices for cracks too and even paint work 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Final inspection tomorrow: Any tips? 4Jun 30, 2009 8:53 pm Also,if you paid for extra insulation in your walls it might pay to somehow see if this was actually done. My friends paid a considerable amount of $ for extra insulation in their internal walls. They made a point of driving past every night and having a 'stickybeak'. The gyprocking was all done internally,but there were the holes in the walls waiting for the light switches to be fitted.Hubby shone a torch in to see the 'inside' of the walls and guess what?-NO INSULATION in any of of the walls at all! They were not happy and its safe to say they let their builder 'have it'. It makes me wonder how many builders have snuck through the 'radar'? Re: Final inspection tomorrow: Any tips? 5Jul 01, 2009 9:27 am Always take a level with you. Bring someone with a keen eye too to put their eye to the walls. It is not too uncommon for walls not to be straight, especially in hallways. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98695 The significant date is when receive final payment invoice Check that section of contract Bit of fluff by builders prior to that 1 15952 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14278 |
