Browse Forums Building A New House Re: WA build Bletchley Park. 61Feb 15, 2010 3:47 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Regards Jeremy Building in southern river Perth.. Re: WA build Bletchley Park. 62Feb 16, 2010 11:49 pm Looking good Jeremy! are you happy with your build so far? The houses are going up in the area so fast!! Building the Pegasus New Generation Bletchley Pk, Southern River Land purchased 03/2009 Contract 06/2009 Prestart 09/2009 Land cleared/sand Pad 10-12-09 Fittings done 17-12-09 SLAB!! 18-12-09 Brickies started 27-1-10 Roof Started 2-3-10 Lock Up 13-5-10 Re: WA build Bletchley Park. 63Feb 17, 2010 12:07 am J-Pedrick The roof frame has now gone up and its looking good!! Last night we had a friend (builder) come and do some measuring/levelling and inspecting of the house, and he picked some stuff up that we need to mention to the builders. Like the main beam running across the roof (6.3meter steel beam) is only sitting on some wood blocks and needs to be solid brick. There is some cracked bricks in the carport that need to be replaced. And just some other little stuff we need to watch.. If anyone is building a house still I suggest you find a builder (friend of a friend) to do an inspection for you. Hi, Did you get those issues sorted with your builder. Like the steel beam ****** on those wood blocks and the cracked bricks. BTW the house is looking good. Cheers, Ed Re: WA build Bletchley Park. 64Apr 23, 2010 1:04 pm [/quote]Hi, Did you get those issues sorted with your builder.[/quote] Sorry for not responding for a long time, have been so busy with a change of jobs and moving in. When i get back in to Perth from the mines i will take photos. We did get the beam looked at and he replaced the blocks with bigger ones, the bad cracked brick's where replaced also. Regards Jeremy Building in southern river Perth.. Re: WA build Bletchley Park. 65May 05, 2010 11:45 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Regards Jeremy Building in southern river Perth.. Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 18022 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8726 |
