Browse Forums Building A New House 1 Jun 23, 2009 8:10 pm Hi All, We are very close to finishing the house with Simonds, and we have been contemplating whether to ask the following brick to be fixed or not. We're not sure whether it is the norm or it's just a lousy brick laying. What do you guys think? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick Question 3Jun 23, 2009 8:25 pm I wouldnt be piccy if it wasnt a PERFECT line. But that is very noticable. I would ask them to fix it. IMO thats not very good. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Brick Question 5Jun 23, 2009 8:48 pm Being a bricky myself, that is correctly laid. As "Brickie" stated it is laid in a half bond for strength , if the line went straight up the wall it would crack. Personally we make most of our internal corners an expansion joint that is then caulked, mostly because it is easier to lay but also looks neater. Technically that brickwork is done the right way and should NOT be a straight line unless it is an expansion/control/articulation joint. Re: Brick Question 6Jun 23, 2009 9:24 pm Thats what is great about this forum. Experts at hand. Well done guys. As most would here have said from that photo that it's not done correctly. By contrast it is done correctly in this instance but not in the best visually pleasing way. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Brick Question 7Jun 23, 2009 10:06 pm wOW REALLY?? Maybe its the mortar that makes it look " a bit off" does it still need to be cleaned?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Brick Question 8Jun 23, 2009 10:28 pm It looks to me like it has already been cleaned, the jointing could have been tidied up a bit, but is not particularly bad just accentuated by the white mortar. Many people would have something similar on their own homes, its just that many people dont take the time to look. mellybuilding wOW REALLY?? Maybe its the mortar that makes it look " a bit off" does it still need to be cleaned?? 2 8356 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12122 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7223 |
