Browse Forums Building A New House 1 Jun 22, 2009 12:55 am I was looking at the latest photos I've taken of the house, and realised that the tiles in the loo have been laid differently than I thought they would. I thought they would start tiling from the middle, rather than the wall. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would you get the tilers to relay the tiles, or leave it as is? Judie Re: Would this bother you? 2Jun 22, 2009 12:58 am which side is the door? Where you are coming from is where you are going to... Re: Would this bother you? 3Jun 22, 2009 1:01 am If the door is hinged on the left of your picture, I'd leave them. Re: Would this bother you? 5Jun 22, 2009 1:46 am In that case, it would really bother me! If I was doing them myself, I'd centre the tile across the doorway, and have equal ones eiter side. I know it's more work - more cuts, but it would be worth it for symmetry. If you wanted to avoid the additional cuts, then I'd want the full tiles in the most exposed part. Re: Would this bother you? 6Jun 22, 2009 8:29 am I'd say centered. But seeing it's already down..i wonder if it won't look too bad once the door is on as the door will cut off some of the view to the full tile to the right. Does it cost to get them to rip it up and redo it? Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Re: Would this bother you? 7Jun 22, 2009 8:41 am I thought tiling was meant to be started in the centre of a room? With the door hinged on the right that would bother me too 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Would this bother you? 10Jun 22, 2009 10:09 pm When we had our tile selection appointment, the consultant went through exactly how we wanted the tiles laid in each room. They called it "square laid" where it was done centred. Unless it is specified in your selections, I'd think you might struggle to get it changed without them charging you. Our custom build with Rossdale http://hazehome.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=17630 Re: Would this bother you? 11Jun 22, 2009 11:21 pm Just looking again... That is lazy work the waste should be split between 2 tiles. A total of 5 extra cuts for semitry Where you are coming from is where you are going to... Re: Would this bother you? 12Jun 22, 2009 11:27 pm Hi Judie, Could you ask them to hinge the door to the left? is this a solution? (our powder room hinges to the left) that way you will be looking at a full tile on the other side. What do you think? (I like the colour of the tiles) T. Re: Would this bother you? 13Jun 23, 2009 12:58 am Wouldn't bother me in the slightest. Every-time I go to the toilet, I have a newspaper with me, blocking out any piss-poor tile work. Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8781 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39742 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2471 |
