Browse Forums Building A New House 1 Jun 17, 2009 10:59 am Has anyone been charged for moving, changing the position of the hot water system on their house. Mine is at the front next to my bed head. I am still at preliminary drawings and have no final drawings. Bearing in mind builders can do what they like, can they charge you via a variation once they see its location on the final plan. I was thinking hey if it’s on the final plan at the back of the house its not a variation it’s on the plan, and must be put there included in the cost. Same with the meter box. Naturally the builder will want it as close as possible to the gas & power pit as it saves them some money in pipe run. Is this correct? Thanks to all Kind regards KW………….. “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Moving hot water system, charge? 2Jun 17, 2009 3:06 pm I moved it from one side of the house at the front, to the other side of the house half way down the side. Cost $350. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Moving hot water system, charge? 3Jun 17, 2009 4:06 pm I asked to move mine at prestart - from the wall the bed head goes against in the master bedroom, a couple of metres along so it goes against the wir wall. I was told no cost, but exactly how far they could move it was determined by a minimum distance to the bathroom. Re: Moving hot water system, charge? 4Jun 17, 2009 8:56 pm moved mine to the other side of the house for no extra cost ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Moving hot water system, charge? 5Jun 17, 2009 9:42 pm We were quoted $340 to move it from one side of the house to the other side. It was originally on the alfresco / entertaining side of the house so we wanted to put it on the other side where the laundry and garage is so it is more out of the way. Building Atlantique by Carlisle Homes in Alamanda, Point Cook Alamanda Stage 8B Re: Moving hot water system, charge? 6Jun 17, 2009 11:14 pm We moved it from the back (we have a wide house with little depth) to the side. No cost, only comment was that the hot water may take a while to reach to bathroom at the other end of the house - but not the ensuite that it will be right next too. We figured the kids normally have baths so the water isn't wasted waiting for the hot, whereas we have showers so wouldn't jump in until it's warm. Paul the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13503 If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25863 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 |
