Browse Forums Building A New House 1 Jun 04, 2009 10:45 pm I'm new to this forum but I have spent weeks reading through all the topics and before I go any further I would just like to thank everyone who has contributed to these forums. I have learnt so much from the forum and would be lost without it I was just wondering if anyone could tell me whether I need to leave the skirtings off to do the floor tiling after handover or the cornices from the ceilings (we're extending the tiling to the ceiling in the bathroom and ensuite). Is it easier for the tiler to have these left off or it doesn't make a difference? I am going for my tender tomorrow and I need to make a decision. Building the Trinity - Waiting to sign contracts Re: Cornices and Skirtings 2Jun 04, 2009 10:49 pm Hiya! Have a look at the Southies thread -- if I'm not wrong, they had their cornices 'packed out' to allow for tiling to the ceiling post-handover. As for skirting, you should ask for it to be 'tacked on' in the contract. It's my understanding this is what people usually do when they are tiling or installing timber floors, so after these are in the skirtings can fixed permanently. Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Cornices and Skirtings 3Jun 04, 2009 10:51 pm We are having floorboards and carpets done after handover and they told us the builder will lose fix the skirtings so that they can easily be lifted off, the floors layed and then they need to be re-attached. I'm not sure about the cornices. Our custom build with Rossdale http://hazehome.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=17630 Re: Cornices and Skirtings 5Jun 04, 2009 10:56 pm woodvillesouth We are having floorboards and carpets done after handover and they told us the builder will lose fix the skirtings so that they can easily be lifted off, the floors layed and then they need to be re-attached. I'm not sure about the cornices. Oh ok. We originally asked for all of it to be left off but they are charging us a ridiculous amount to return and install the cornices. As for the skirtings, they were to be delivered primed but not painted which is too much hassle for us. We will ask for them to lose fix the skirtings. Thanks for the tip. Building the Trinity - Waiting to sign contracts Re: Cornices and Skirtings 6Jun 05, 2009 7:13 am Cornices : you have to ask your builder to pack out your cornices if you want to tile all the way up, after handover. This will be a variation if done post contract. We paid approx $525 to do 3 bathrooms & 1 toilet. What they will do is actually install your cornices, leaving a 1-2 cm (don't remember) gap between them & the wall. Sorry I don't have any pics. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Cornices and Skirtings 7Jun 05, 2009 7:25 am If you're tiling floors, there's no real need to leave skirtings off, as it's easy to get a neat edge with tiles. The only real advantage to adding the skirtings over the tiles is that you don't lose any height. It's mroe commonly done with floor boards, to avoid the need for timber quad trims along the edges. But think about it - if you have any adjoining carpeted areas with no architraves in between, you'll end up with skirtings at different heights... Some builders won't even do tacked-on skirtings, or leave them off. Ours wouldn't. If skirting height once the flooring is laid is your concern, you can always upgrade to bigger skirtings. I think the standard for our builder was 60-odd mm. We upgraded to 92mm. There are an even taller ones available. Re: Cornices and Skirtings 8Jun 10, 2009 9:04 am Thanks for your help everyone. We went for our tender on Friday and our builder advised that packing out the cornices is not an option. They said that they could leave them off completely but were charging us in the thousands(!!) for them to return and install the cornices after tiling was done. As for the skirtings, we decided to leave them on as our builder told us it would be our responsibility to measure, cut, paint and install the skirtings on our own after handover, which quite frankly I don't have the patience in doing Building the Trinity - Waiting to sign contracts I already have the doors and architraves installed as pictured. My question is which size n type of skirting would go with the architraves? I originally wanted a winder,… 0 3263 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10032 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 |
