Browse Forums Building A New House Re: Roughly How Many Bricks to Build a house ? 2Jun 04, 2009 10:09 pm The plan we are building, counting all the pallets on other constructed sites there was around 8500 for 36sq single storey. Bit of glass around though. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Roughly How Many Bricks to Build a house ? 3Jun 04, 2009 10:11 pm I would say probably between ~9000 at a guess... 10000 would be a safe bet Building Monaco32 with Carlisle Homes in Alamanda Estate 20/08/2010 - HANDOVER 24/8!! Blog - http://ourmonaco32.blogspot.com/ Thread - viewtopic.php?f=31&t=14415 Re: Roughly How Many Bricks to Build a house ? 4Jun 04, 2009 10:27 pm Hi Des single brick or double - if outside only how high how many doors & windows?? where r u building? cos in WA we can send plans to austral & they'll do an estimate 4 u. if u want a better estimate post up ur plans .... to many variables to be any help otherwise, reason i say this is that i've just built a 440 sq d/brick (u can see it in Owner Builders forum "Our last O/B & still fun) - total of 14,109 bricks & that included a lot of "small bricks" over door & windows on inside walls. Austral Feds on outside 3036 blocks, 220 snaps, 264 halves,132 sills, 88 solid cored for under doors. remember if u want to run 1/2 bond as u can see in mine, u have to get a brickie who will be prepared to cut blocks or u buy (waste) a lot of snaps. 1/3 bond is easier but IMO looks crappy. sorry to those who have 1/3 bond... cheers tony Re: Roughly How Many Bricks to Build a house ? 5Jun 04, 2009 10:43 pm T&V Hi Des single brick or double - if outside only how high how many doors & windows?? where r u building? cos in WA we can send plans to austral & they'll do an estimate 4 u. if u want a better estimate post up ur plans .... to many variables to be any help otherwise, reason i say this is that i've just built a 440 sq d/brick (u can see it in Owner Builders forum "Our last O/B & still fun) - total of 14,109 bricks & that included a lot of "small bricks" over door & windows on inside walls. Austral Feds on outside 3036 blocks, 220 snaps, 264 halves,132 sills, 88 solid cored for under doors. remember if u want to run 1/2 bond as u can see in mine, u have to get a brickie who will be prepared to cut blocks or u buy (waste) a lot of snaps. 1/3 bond is easier but IMO looks crappy. sorry to those who have 1/3 bond... cheers tony Re: Roughly How Many Bricks to Build a house ? 6Jun 04, 2009 10:46 pm Isn't this one of those "how long is a piece of string?" questions? The reason I say this is because (stating the bleeping obvious!!) all houses are different. You want an average? Ours will be 2-storey, approx 40sqs and approx 13-14 thousand bricks. Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Roughly How Many Bricks to Build a house ? 7Jun 04, 2009 11:31 pm ours is a 25sq place and about 8000 bricks! 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Re: Roughly How Many Bricks to Build a house ? 8Jun 05, 2009 12:15 pm we are all guessing without a plan. It works out at 48.5 bricks per square meter. Easiest way is to work out the total m2 of your external walls and then subtract your openings (windows, doors, etc) add a couple of extra hundred for wastage. Re: Roughly How Many Bricks to Build a house ? 9Jun 05, 2009 12:39 pm There used to be a website that would approx calculate it for you. Saw it when we were negotiating brick choices. Must have been on either the Austral or Boral or PGH websites - they were the only ones we looked at. Here it is..... http://www.boral.com.au/brick_calculato ... ckinsights Some things are worth waiting for. Re: Roughly How Many Bricks to Build a house ? 10Jun 05, 2009 12:46 pm Bananas we are all guessing without a plan. It works out at 48.5 bricks per square meter. Easiest way is to work out the total m2 of your external walls and then subtract your openings (windows, doors, etc) add a couple of extra hundred for wastage. With these calculations we are at around the 14-15,000 bricks.... Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Roughly How Many Bricks to Build a house ? 11Jun 05, 2009 1:45 pm I would have thought at least a million? Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Roughly How Many Bricks to Build a house ? 12Jun 05, 2009 2:02 pm Desmondp, My house is just under 160sqm, 2700mm ceilings, with roughly 46 metres of brick wall. It's about 5500 (brick veneer). If you really want to be technical: Length of brick wall (m) x ceiling height (m) / 0.25 / 0.086 + a bit for wastage - a bit for windows In my case, 46 x 2.7 / 0.25 / 0.086 = 5776. 0.25m = 240 brick length + 10mm for mortar. 0.086m = 76 brick thickness + 10mm for mortar. I'm also using Austral. Chris Re: Roughly How Many Bricks to Build a house ? 13Jun 05, 2009 2:05 pm our bricks were 210m2 living plus 5 pillars = 8300ish bricks they will allow for atleast a 5% wastage too i think. we used selkirk bricks and all local brikkies said they were bad so to allow 10%... we had hardly any brocken or chipped bricks at all! Re: Roughly How Many Bricks to Build a house ? 14Jun 05, 2009 7:39 pm I used blue onyx and they were $1200 per thou, I did get them at builders rate but I doubt the builder will pass on that rate. At the $1200 price I would say it would be up there in regards to category. Re: Roughly How Many Bricks to Build a house ? 15Jun 05, 2009 11:19 pm Ours was approximately 15000 - It was a double storey home Re: Roughly How Many Bricks to Build a house ? 17Jun 06, 2009 9:53 pm Yak_Chat Casa2 Said Quote: Very roughly 10,000 bricks (for outside/brick veneer only). Probably a touch less. Internal Brick Veneer Are you saying my rough estimate is wrong? Demolition August 2009, Construction Started September 2009, Completed December 2010 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105617 They already have two well known ones (HIA & MBA) that many new home buyers mistakenly think are regulatory bodies that Joe Public can complain to. 6 18030 Interesting. You have great clearance to damp proof course all the way around which is rare with so many cowboy landscapers and concreters. Is there sufficient fall… 2 2436 |
