Browse Forums Building A New House 1 May 28, 2009 4:36 pm In our contract there is a provisional sum of $2,000 for the removal of excess soil. I've asked that this be removed as I'd like to keep the soil and use it at a later time (also a tip I got from another DFH customer). But I've been told that it can't be taken out because "it will be a lot of soil that comes out so it can only be determined onsite if there is any room to leave it on site but generally the standard size blocks do not have enough room." Forgive my ignorance but is this usual practice or a money spinner? $2,000 seems a lot to me for this service. Building with Dennis Family Homes - Hartley 280 Location: Settlers Run, Botanic Ridge Re: Soil Removal Cost 3May 28, 2009 6:36 pm This is my $1,000 pile of dirt. Nice huh. IMO if you have enough room for the dirt you should be allowed to keep it. I can see how it would be a problem if it was in the way. Good luck. The Undertaker took ours away. Re: Soil Removal Cost 4May 28, 2009 8:13 pm bobcat and tandem truck (not truck and dog) $90 a hr + gst usual min. 4 hr landtrak site dump $45 per truck av. 12 q/m a tandem truck or tip as clean fill app. $50 a load 20% odd builders if supervised app. $45 - $130 hr min 4 hr app. most bulk outs are an estimate only, no real way of determining amount of soil after excavation (soil fluffs up etc when excavated) Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Soil Removal Cost 5May 29, 2009 12:39 am Be happy its only dirt. I have a pile of dirt that size and then two bigger piles of excavated rock next to it. The wallets gonna hurt getting that taken away. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: Soil Removal Cost 6Jun 02, 2009 8:18 am Hi, We had been charged the same provisional cost for soil removal however we got out sales consultant to put a note on the contract stating that they are to leave all excess soil on site and only under the instruction from us is it to be removed, so this money will be credited back in the final payment if the soil hasnt been removed. Re: Soil Removal Cost 7Jun 02, 2009 9:22 am when we did our selections it was mentioned that we would need to remove the soil within 7 days of the slab being poured.....we will see about that...its my soil and besides we have a 1161sqm block so there is more than enough room for the soil, house and builders waste. http://buildingatfreeling.blogspot.com/ Building at Freeling Estate Adelaide MKII WE ARE NOW OFFICIALLY FIRST HOME OWNERS AND WE BUILT A NEW HOME FROM SCRATCH Re: Soil Removal Cost 8Jun 02, 2009 9:36 am We have also requested that they leave the soil. We'll have a lot of soil because we have a 2m slope and the house is a big single storey. We actually had it included in our contract that it was to be piled at the back of the block. We got charged for it to be moved and piled (I sh*t you not), but the charge was minimal and nowhere near the removal cost. It's still costing someone time and money to move all the soil I guess. We have a 1639m2 block though, so room and access wasn't an issue. Not sure whether my builder does it on standard sized blocks. This is a good thread though..... because it's worth anyone thinking about keeping their soil rather than removing it. Our soil is really good... I couldn't see the point of removing it, then bringing in top soil at a later date. I'll just use my excess when the build has finished and feed the soil as Fu says. Seemed like a more cost effective way of doing things. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Soil Removal Cost 9Jun 02, 2009 5:48 pm Our 2nd home we decided to have the soil stockpiled at the rear of the block because we didn't think it would be a lot (flat block). Big mistake! It was big, maybe twice the size of Carmel's. We called it the 'volcano'. The problem... We didn't have any access to the rear after the house was built. When I say no access I mean, we couldn't even fit a wheel barrow down the side because the hot water system was blocking the path. It took 5 of us with shovels and barrows about 4 days to clear it away. Actually we used about 1/2 in the back yard to level it out and 1/2 was carted away. Thanks to our neighbour for letting us remove a section of the fence! If you do have access to the rear for at least a dingo (the machine not the one that eats babies) then i'd suggest having it left on site at the rear so you can use what you need and have the rest removed after build. If you don't have access or don't think you'll use it - get the builder to remove it. I recently got the engineering report back for my current house and they calculated that 1000 tonne needed to be removed @ $16 per tonne ($16,000). So that gives you an idea of the cost. Re: Soil Removal Cost 10Jun 02, 2009 5:55 pm Similar story to Joles - we have a 3.5mt deep cut across approx 25 mts so there will be a lot of soil removed, anticipating 3 days of it. We are not being charged to remove any of it and we are not keeping any of it. We are having a pool put dug out in Oct / Nov and will probably keep some of that instead. JL Re: Soil Removal Cost 11Jun 15, 2009 9:43 pm Hi all - I'm in the same position right now, we have a $2,500 provsional allowance by our builder to remove excess fill from site - he had assured me that based on his calculations this should cover it..... Well, since the excavations have begun to prepare for the slab, I've had nothing but dropped comments from builder and excavators alike, saying "There's a lot of dirt..."... I am yet to see the cost difference, but I do know from a reliable source that a truck and dog (10tonne truck + trailer = 20 tonne) is about $800 per load including bobcat etc. I wait with stress and tension tyo see what the builder charges me. By the way, has anyone requested proof of the amount of dirt, ie actual cost, from their builder?? Francesco. P.S Going by the phto in this thread - in my inexpereinced view, it looks like a <$1,500 pile of soil. Re: Soil Removal Cost 12Jun 15, 2009 10:25 pm Andronicus I recently got the engineering report back for my current house and they calculated that 1000 tonne needed to be removed @ $16 per tonne ($16,000). So that gives you an idea of the cost. Are you sure it wasn't 1000kg? 1000 tonnes is crazy. I recently carted away 33 tonnes (33 000kg) of dirt and rock. I organised it myself, builder suggested someone but this guy said he'd do a good deal If I paid cash. It took three truckloads... Breakdown: Labour: $85p/h (one man, excavator and truck) Hours: 4.5 hours Dumping fee: 3 tonnes free (resident) and each additional tonne at $6.50 Total: $577.50 I paid less than that though. The nice lady at the tip let me off for the last load saving me about $65. Pretty silly you have to pay so much any way since it was clean fill, the tip use it to cover up rubbish. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: Soil Removal Cost 13Jun 30, 2009 5:33 pm alk Are you sure it wasn't 1000kg? 1000 tonnes is crazy. I recently carted away 33 tonnes (33 000kg) of dirt and rock. I organised it myself, builder suggested someone but this guy said he'd do a good deal If I paid cash. It took three truckloads... Breakdown: Labour: $85p/h (one man, excavator and truck) Hours: 4.5 hours Dumping fee: 3 tonnes free (resident) and each additional tonne at $6.50 Total: $577.50 I paid less than that though. The nice lady at the tip let me off for the last load saving me about $65. Pretty silly you have to pay so much any way since it was clean fill, the tip use it to cover up rubbish. Yes, 100% positive it is 1000 tonne. It is crazy, but imagine taking a 2.6m deep cut into the land 20 metres wide, you'd reach 1000 tonne quite easily. That's not even cutting out a square chunk, it's more like a wedge shape (due to the land sloping). It's interesting to compare your price ($17.50 per tonne) with my builders price ($16.50 per tonne). I wouldn't be able to stockpile that amount, it'd be as high as ayers rock. Re: Soil Removal Cost 14Jun 30, 2009 7:33 pm We just had a quote done today for the removal of approx 30m3 - not sure how much that would weigh I was told $90/hr (cash) for the bobcat and removal plus tip fees of about $270 if he couldn't find somewhere / someone looking for free fill. All up it will apparently cost us about $720 at that rate. We had asked for ours to be left on the block so we could use it for raised garden beds. But its shocking clay and just in the way of any landscaping effort, so it's got to go. We'll need to dig more out for the driveway and possibly where we're going to build the deck, so it wont be missed. Re: Soil Removal Cost 15Jun 30, 2009 10:45 pm We just went through the same thing The soil was $5 a cubic metre to dump at a fill site LANTRUC The tip truck was $75 an hour The excavator as $85 an hour Basically we were quoted 200 cubic metres or 20 tip truck loads, excavation and tip fees for $6000. I suggest you get onto lantrak and speak to them about prices, they sem to be pretty good! Re: Soil Removal Cost 16Jul 01, 2009 1:09 am Andronicus alk Are you sure it wasn't 1000kg? 1000 tonnes is crazy. I recently carted away 33 tonnes (33 000kg) of dirt and rock. I organised it myself, builder suggested someone but this guy said he'd do a good deal If I paid cash. It took three truckloads... Breakdown: Labour: $85p/h (one man, excavator and truck) Hours: 4.5 hours Dumping fee: 3 tonnes free (resident) and each additional tonne at $6.50 Total: $577.50 I paid less than that though. The nice lady at the tip let me off for the last load saving me about $65. Pretty silly you have to pay so much any way since it was clean fill, the tip use it to cover up rubbish. Yes, 100% positive it is 1000 tonne. It is crazy, but imagine taking a 2.6m deep cut into the land 20 metres wide, you'd reach 1000 tonne quite easily. That's not even cutting out a square chunk, it's more like a wedge shape (due to the land sloping). It's interesting to compare your price ($17.50 per tonne) with my builders price ($16.50 per tonne). I wouldn't be able to stockpile that amount, it'd be as high as ayers rock. 2.6 x 20 = 52 cu mtrs @ an overly generous sg of 2.8 = 145.6 t We levelled an area 45m x 35m x 1.5 mtr cut and 1.5 mtrs fill, was bush we moved 2300 cu mtrs of sand. Cost of $3160. No sand was removed or brought to site. But it was a contra deal. Where you are coming from is where you are going to... Re: Soil Removal Cost 17Jul 01, 2009 2:07 am onc_artisan 2.6 x 20 = 52 cu mtrs @ an overly generous sg of 2.8 = 145.6 t We levelled an area 45m x 35m x 1.5 mtr cut and 1.5 mtrs fill, was bush we moved 2300 cu mtrs of sand. Cost of $3160. No sand was removed or brought to site. But it was a contra deal. Need to factor in the entire building envelope. Something like 2.6 deep x 20 wide x 16 long x your factor of 2.8 = 2330 t. However since the land slopes down over that 16m (eg it's not 2.6m deep the whole 16m) that you end up digging out a wedge rather than square. So perhaps 1/2 the 2330 t or 1164 t. Because the original plan was all cut, we couldn't use the soil for filll and thus the need to spend $16 per tonne having it removed from site. I didn't mention the $4500 charge to actually do the siteworks. Re: Soil Removal Cost 18Jul 01, 2009 2:11 pm You need to find someone like me (and I need to find someone like you all) who wants some fill. Anyone on the southside of Brissy with some dirt to give away to a good home??? Building the Pl@ntation Retreat on 4009m2. All moved in!!!!!! Now for the real work https://forum.homeone.com.au/viewtopic.php?f=31&t=20588&p=285640#p285640 Re: Soil Removal Cost 19Jul 01, 2009 5:41 pm could walk down the main streets of adelaide with a handfull of soil singing.. Some Soil, Soil for sale. It's going cheap. Only seven guineas. That -- or thereabouts. Some soil... Rather pale. ... Re: Soil Removal Cost 20Sep 29, 2009 8:02 am hunts01 We just went through the same thing The soil was $5 a cubic metre to dump at a fill site LANTRUC The tip truck was $75 an hour The excavator as $85 an hour Basically we were quoted 200 cubic metres or 20 tip truck loads, excavation and tip fees for $6000. I suggest you get onto lantrak and speak to them about prices, they sem to be pretty good! Was that including the operators hourly rate for tip truck and excavator? We are querying our concreter as they've overcharged on every conceivable thing. To remove 35.64 cubic metres of fill they charged 2800 for a combination rock breaker, 6 tonne excavator and bobcat, and 2735 in tip truck hire (395 tip fee's 5*79= 395). they say they took 22 trucks to the tip and were only charged for 5. The first day's excavation they removed most of the soil from the block the majority of the excavation for the retaining wall with supposedly 4 loads (about 27 cubes) this took the operator 6 hours. The second two days they removed the leftovers (probably a truck full), + 8.64 cubes of material for the footings some of which was rock. So excavation cost for 35 square metres (including labour of operator of excavator and supervisor for excavator (50 per hour= 2600) was $8135 or $232.4 per cubic metre. Figure that one out ! Also they excavated the footings using the same "technique" and for approx 18 cubes of footings they charged 3410 for the excavator and tipper (11 hours @ 90 for the tipper =990+ 20 hours excavator bobcat rock breaker combo 20 hours *110= 2200,+ tip fees 4 loads @55.05 = 220.20) Mysteriously the tip fee had dropped it's fees by 30 percent the second time and they were able to take 18 cubes in 4 trucks, as opposed to 35 cubes in 22 trucks. This is using a 10 cubic metre truck by the way, and the bob cat and rock breaker weren't used in the first day of excavation, i wasn't there for the rest so i don't know what happened. Also the company that do the concreting own the excavation equipment and rent it out to themselves through a shell company as their address is the same as the concreter so we can't get the actual time rented out from the machinery hire place as it's their company. PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10265 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37231 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6361 |
