Browse Forums Building A New House 1 May 27, 2009 3:06 pm Can you please help me find a solution with these taps. We have installed Dorf Fluid taps with a Fowler Seido inset basin the problem is the taps have been installed too low and there is barely any room to put your hands under - how do I fix this problem without moving the taps? I have thought about getting a gooseneck spout but they come out longer so would be too far for the basin. Help please??? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Taps too low - How do I fix this?? Help please 2May 27, 2009 4:09 pm Re: Taps too low - How do I fix this?? Help please 3May 27, 2009 4:16 pm I’m amazed the plumber didn’t say anything before he did it! Another case of….who cares. My plumber told me, that you have to change everything….taps and spout when you want change one thing, as the fittings are different on them all. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Taps too low - How do I fix this?? Help please 4May 27, 2009 4:56 pm the spout length can't be longer than 200mm - as it will be too far out (basin only 310mm) I'm finding the gooseneck although ideally higher are also longer... Re: Taps too low - How do I fix this?? Help please 5May 27, 2009 5:01 pm hermyleen the spout length can't be longer than 200mm Good idea for the bath spout check out this site http://houseoftaps.com.au/index.php?main_page=product_info&cPath=8&products_id=12&zenid=908cd1ed453a3a7dfe0a36e872abfcdc 200mm bath spout for $50 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 7303 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24692 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2550 |
