Browse Forums Building A New House 1 May 21, 2009 10:17 pm Hi all Ever had to wait, wait & wait till the hot water finally comes out of the tap hot? Does it make a difference were your hot water system is positioned. Like, if it’s close to the kitchen sink then the water will be hotter quicker. Will having it on the kitchen side of the house make that much difference? What is the difference is between continues flow & mains pressure hot water? Thanks people. Cheers KW.......... “It's just as unpleasant to get more than you bargain for as to get less” George Bernard Shaw. Re: Position of your hot water system? 2May 22, 2009 6:54 am KW, You can roughly work out how long it will take hot water to come from the system to each tap... Work out the metrage of the 12mm or 1/2 inch pipe... This is a good guide on how many seconds it will take to get to the outlet... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12475 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20220 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24140 |
