Browse Forums Building A New House 1 May 20, 2009 1:37 am Our insulation was put in today, but of course I've changed my mind and want more done. I offered the installer cash to do it, which he wanted to, but had to check with his office first to find out if he's available. He's not The plasterboard will be started on Thursday, so that only leaves Wednesday to get it done. Does anyone know of someone on the north shore in Sydney who might want the job? Alternatively, how hard + complicated is it to do yourself (it would only be me)? TIA Judie Re: Help! need insulation installed quickly 2May 20, 2009 8:36 am tomorrow ?? what size area do you need to do yourself?? It might be too big a job for y just yourself to do in 1 day Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Help! need insulation installed quickly 3May 20, 2009 10:41 am Judie Our insulation was put in today, but of course I've changed my mind and want more done. I offered the installer cash to do it, which he wanted to, but had to check with his office first to find out if he's available. He's not The plasterboard will be started on Thursday, so that only leaves Wednesday to get it done. Does anyone know of someone on the north shore in Sydney who might want the job? Alternatively, how hard + complicated is it to do yourself (it would only be me)? TIA Judie Well you have 1 day provided that you can get on site. I'd get out there right now and start installing. If your installer turns up then thanks your lucky stars, if not, at least you've got some / most of it out of the way. We where told the builders need 1 full day to install insulation. So I'd suggest you start with the main areas you want covered first. ie. Bedrooms / family room. ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: Help! need insulation installed quickly 4May 20, 2009 11:13 am if you have seen how it's been installed, it's actually quite simple. Any one can buy a few bags of insulation material from Bunnings, month mask, a long stick with nail/hook attached to one end, hammer, some nails and long strings to hold the materials, and that's about it. But there's also the dark side about DIY before plaster walls started: health/safety concern, insurance if anything goes wrong, site supervisor has every right to kick you out, how do you know if the areas near power points/eletrical stuffs been installed correctly, ....etc. Also have a look at this post my blog below, if the brick cleaner were arranged before some ceiling/wall not completed, it might be a disaster. Since you did certain areas by yourself, you have to fix it.... http://building-our-first-house.blogspo ... trous.html Good luck! The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 12591 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 23165 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 8927 |
