Browse Forums Building A New House Re: Another site question: what does this level mean? 2May 16, 2009 11:05 am I am not sure what it means - perhaps the ratio of the fall from front to back?? I wouldn't think it is 1ft 15 in though as surely all measurements in Australia(I presume you are in Australia ) would be in metric and anyway 1 ft 15 inches would be 2 ft 3 inches in imperial measurements, wouldn't it Re: Another site question: what does this level mean? 3May 16, 2009 11:45 am I think it means that it falls to the north at a 1:15 ratio. Ie 1cm per 15cm or 1m per 15m (same thing) Building Monaco32 with Carlisle Homes in Alamanda Estate 20/08/2010 - HANDOVER 24/8!! Blog - http://ourmonaco32.blogspot.com/ Thread - viewtopic.php?f=31&t=14415 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 1215 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 13363 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 5049 |
