Browse Forums Building A New House 1 May 13, 2009 5:38 pm This might be a dumb question but what is a "meter assembly" that has to be installed before they can fit a water-meter. And how do I tell if I already have one? Trying this building gig one more time. Re: Water Meter Assembly 2May 13, 2009 10:54 pm Hey virgin-builder, The meter assembly, or meter frame, is the section of water pipe that comes out of the ground. It is usually found close to the front boundary, where your home is connected to the mains water supply. Is you have a pre-laid service, which most new estates have, you should already have this frame sticking out of the ground with a spacer pipe in it waiting for the meter to be affixed when you're ready. Re: Water Meter Assembly 3May 14, 2009 6:42 am Thank you IkonInteriors! You won't believe how hard it is to get a straight answer from the water company Trying this building gig one more time. 4 10824 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 |
