Browse Forums Building A New House 1 May 05, 2009 11:29 pm Howdy I am planning an ouside living space adjacent to a ground level cement slab house. I dont want a step down to a paved area coz of wheelchair access. My only option [maybe] is to install decking to keep the ouside the same level as the floor inside. But ... Decking [wood] doesnt last. Maybe i can build it out of steel and cement fibre board? Maybe coat it with marine 2 pac and antislip [like on boats] Any thoughts ? Suggestions? Would that epoxy 2 pac paint last 20 years? Is cement an option? But where does the storm water go if i use cement? All help appreciatted. Noremac Re: outside living area floor level with inside floor level? 2May 06, 2009 4:53 pm noremac Howdy I am planning an ouside living space adjacent to a ground level cement slab house. I dont want a step down to a paved area coz of wheelchair access. My only option [maybe] is to install decking to keep the ouside the same level as the floor inside. But ... Decking [wood] doesnt last. Maybe i can build it out of steel and cement fibre board? Maybe coat it with marine 2 pac and antislip [like on boats] Any thoughts ? Suggestions? Would that epoxy 2 pac paint last 20 years? Is cement an option? But where does the storm water go if i use cement? All help appreciatted. Noremac This product would fit your needs... http://www.futurewood.com.au/ I have a sample and it looks good. You can concrete, but it will need a drainage channel at your door. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: outside living area floor level with inside floor level? 3May 06, 2009 6:46 pm I guess it depends on how long you plan on being around, but we found decking to be a long-lasting option. Our batu decking was installed in 1987 and we sold that house with the deck in perfect condition in 2007. In that time we replaced two planks that had split or warped and stained the timber (a quick job with a roller on a pole) maybe four or five times. Not a lot of maintenance over 20 years, and it was a high-traffic area too. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16538 3 5580 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17511 |
