Finalising custom plan for a long skinny house, and currently hallway is 1m wide - is that wide enough or will it feel cramped? Obviously it would be nice to have it wider, but as the block is on 9.14m wide, we don't have a lot of width to play with.
Any thoughts?
Hallway - how wide?
Any thoughts?
I'm not a huge fan of the 900 hallway - does seem a bit cramped. The house we are building had a 920 hallway in the display, we made it just a fraction wider to 1020. Personal preference though - I know someone to have made their 1050 hallway smaller to 900.
If I only had 9.14m to play with....I probably consider the extra 100mm better spent on common areas or bedrooms.
Our hallway is 1.2m wide. I would have liked it wider, but it would have compromised the width of other rooms. I preferred to have the extra space in every other room that goes along my hallway than in the hallway itself.
As well as height I would consider the length of the hallway. Ours is about 9m long. Here is a pic from about halfway down.
As it is such a long skinny house already, we're thinking about potential resale value down the track as well as living in it in the nearer future. Trying to get a balance of useable space in bedrooms etc vs. not looking too cramped or skinny when you walk in. I certainly wouldn't consider anything less than 1m.
Justin.
2
Might cheaper to changer your idea of what makes a home, have you considered building a porch?
21/10/2023
2
at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with…
9/02/2024
8
What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make…
