height of Monolithic slab
In order not to place the tanks too high or low in relation to the house we have to know how high the threshold of the laundry door will sit. The first tank will be placed at a distance of 4.5 meters from that point and the top of the lid should sit 100mm higher than the surrounding soil.
The house pad is cut/fill to 14.78AHD with a max crossfall over the house area of 0.45 m. We have a good idea where the cut and where the fill will be so if somebody would know how much the slab will add to that we might be able to figure out how deep the exavator has to go. The tanks are 2.8 mtr high, so normally he has to go 2.6 mtr deep to allow 100mm gravel at the base. By adding the extra height of the slab and threshold we would be able to get the distance between the house and edge of tank level
or could we get this info from the surveyers without asking them to come on site again? They already are charging us $1200 for replacing a couple of missing PEGS so I don't want them around to much.
cheers
2
ok thanks - yes was wondering if that should have been listed as Option Three!
27/06/2023
2
I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks
28/07/2023
16
i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices
