Hi,
We took the extended option on the PD Davenport house and it cost $3901 plus the upgraded slab on the floor. We will deck after handover. I believe it really makes this area. Go got it if you can!
Cheers
OutofAfrica
Browse Forums Building A New House Re: Larger Alfresco ? 21Apr 21, 2009 9:45 pm Hi, We took the extended option on the PD Davenport house and it cost $3901 plus the upgraded slab on the floor. We will deck after handover. I believe it really makes this area. Go got it if you can! Cheers OutofAfrica Kruger National Park - An amazing place to visit Re: Larger Alfresco ? 22Apr 21, 2009 10:35 pm Hi Rex, I am in agreeance with upgrading the alfresco, if you can justify the expense..and the wife can be convinced. As joles said, both have advantages and diadvantages and it is a case of weighing them up and making a personal choice. For us we have selected to upgrade ours for entertaining reasons, and because I personally like the seamless look, however, I have also seen some really nice pergolas. Goodluck with the decision. Re: Larger Alfresco ? 23Apr 21, 2009 11:41 pm The decision for us has been purely financial. The area that we intended to use for entertaining is biggish (will try to get dimensions) and Masterton quoted us almost $20k to build an alfresco! We decided to just have the area paved or concreted/stencilled when we're doing our driveways and we'll build a pergola over it a bit down the track. Your quote sounds very reasonable. Masterton Santorini Grande 23/01/09 First Tender 17/11/09 Contract signed 25/01/10 Slab 27/03/10 Frame 7/5/10 Bricks 1/07/10 Roof 9/7/10 Lock up 24/8/10 PCI 16/09/2010 KEYS! viewtopic.php?f=31&t=16418 Re: Larger Alfresco ? 24Apr 22, 2009 10:14 am Thanks guys. After a quick chat lastnight with DW it looks like it should be a goer! I want to go to our the block and measure out the size difference first but, as this will give us both a better idea of just how much of an improvement it will be and put our mind at ease at the extra-stretch on the budget. Cheers again. Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4194 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4890 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1665 |
