Browse Forums Building A New House 1 Apr 04, 2007 11:19 am All i'm after a bit of advice here.
Our house is at fixing stage so roofs on , sparkies been, and the brick just started. However the certifier has halted works as an internal load bearing wall frame over hangs the slab by about 15mm . An he wants an engineers report on it. The garage slab is lower than the actual floor slab , when the framing was put up the framing ran true at the front of the house but over hangs by about 15mm at the rear. It's a 90mm frame. The builder has packed the "gap" with timber as has dynabolted horizontally into the floor slab to support the frame. The actual frame is fixed to the slab not the packing timber. Our supervisor assures us this is normal as the slab pour is never that accurate and the certifer is over reacting . A report is being done but i'm wondering whether i should get an independant assesment done for piece of mind ? What if the down the track this becomes an issue ? Cheers Re: FRAMING OVER HANGING SLAB ? 2Apr 04, 2007 11:46 am Hi Marshy,
We had a similar issue for our garage, the frame hung over the slab. I didn't think much of it, however a few days later a concreter had been and had placed more concrete under the frame so there was no frame over hanging. Hope this helps. Re: FRAMING OVER HANGING SLAB ? 3Apr 04, 2007 11:58 am The 'Guide to Standards & Tolerances' allows for a max. of 10 mm overhang. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 2331 ![]() If I was to do this I would add extra supports in the ceiling cavity that are independent of any ceiling joists or truss bottom chords. The extra load of the bed wouldn't… 1 1309
Cheers for that..
plastering wall and getting it even/smooth/square sounds like it might be above my patience/paygrade 2 3971 |
