Browse Forums Building A New House 1 Apr 11, 2009 1:10 pm We asked for a capped cold water point to Fridge Space in our Pantry. Is this what it is? Or do we need a tap thingie at the end of it? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks. Built PD Beaumont 35 - One year down in the new house.. still so much to do.. Re: Water point in Pantry... is this what it is? 2Apr 11, 2009 2:12 pm MKR We asked for a capped cold water point to Fridge Space in our Pantry. Is this what it is? Or do we need a tap thingie at the end of it? Yep thats it a "capped cold water point" no tap! Cheers Cozmo ______________________________ Building a PD Heywood 29 http://fromevetoeternity.blogspot.com/ Re: Water point in Pantry... is this what it is? 4Apr 11, 2009 2:46 pm Just turn your water off at the meter (stop ****) then connect your fridge to it (hose usually supplied) - easy peasy Japanesy John, Tarin and the Kids Built and moving in to the Regent Grande with Masterton homes http://thebrownsaremovingtothecountry.blogspot.com Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5203 I visited a relatives house and he went with sink in kitchen and butlers, dishwasher in kitchen and butlers and has crockery spread out between the two areas depending on… 2 44072 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9242 |
