Browse Forums Building A New House Re: M3tricon Vs Private Builder 10Apr 10, 2009 3:57 pm -------------------------------------------------------- Building in Highlands Craigieburn Status: Building the Laundryless 25.5: Slab Complete Re: M3tricon Vs Private Builder 11Apr 10, 2009 5:14 pm We originally went down the path of paying for a custom builder to do plans but went away from that idea in the end. It was a lot more expensive at a base price before we talked about upgrades which most volume builders were throwing in. The final deciding factor was being able to walk through a display and actually feel what the house was going to be like rather than off a set of plans. I also was concerned that it is hard to check the reputation of a smaller builder. They only give you contacts of people who are going to give good responses. I think in Warnabool they would be using local builders. First find out if they are reputable and then compare apples with apples. And fingers crossed they extend the FHOG! Fi has moved in!! If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25863 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11753 |
