Browse Forums Building A New House 1 Apr 07, 2009 5:06 pm Hi, My neighbour had just started construction and their block has a zero lot line. Does anyone know where i can find out details or regulations on zero lot lines. reason I ask is..... their garage will form part of our fence, as they are building right up against the boundary. I have notices their slab is right up against the boundary. What happens to their eaves?? will they hang over on our block?? Is that legal??? Maybe they dont have eaves at all?? is that possible??? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 2Apr 07, 2009 5:13 pm Yes it is possible. They will not have eaves and the gutter will sit on top of the brickwork so that no part of their build will be over your boundary. It is common practice on narrow blocks. Re: Zero Lot Lines???? Help 3Apr 07, 2009 5:39 pm This sounds like its a parapet garage wall. If this is the case there are no eaves or gutters and its basically considered on your behalf to be a brick fence. In WA the owners are required to ask you what colour render or face brick you would like. It doesn't sound like you are in WA or this would have already happened. Maybe research Parapet walls instead. Re: Zero Lot Lines???? Help 4Apr 07, 2009 5:58 pm Thanks gweluphome and klscomps !!! I had a look at parapet walls. Every circumstance Ive seen shows that the neighbours need to be consulted. Im not sure if this applies in Qld. I have no issue with them building on the boundary ( as long as it stays within their lot... of course ) as I have 25 mtr frontage But I wonder what happens now with regards to colour. I wonder whether I am allowed to paint or colour that wall??? The colour they pick for their house may clash with my own colours. Is that side of the wall considered to be part of their house AND part of my fence.??? or just part of their house. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 5Apr 07, 2009 6:12 pm From what I have experienced, you should have been consulted unless they are reinstating your fence over the top. You should now be able to choose what colour if its going to be rendered and you don't like the colour they are painting it. Or what is quite common is for them to do the parapet in a neutral coloured face brick such as limestone colour. But it is essentially your wall to drill into and hang things off if you like I would contact the council or there builder if you don't know what your rights are. Re: Zero Lot Lines???? Help 6Apr 07, 2009 6:28 pm gweluphome From what I have experienced, you should have been consulted unless they are reinstating your fence over the top. You should now be able to choose what colour if its going to be rendered and you don't like the colour they are painting it. Or what is quite common is for them to do the parapet in a neutral coloured face brick such as limestone colour. But it is essentially your wall to drill into and hang things off if you like I would contact the council or there builder if you don't know what your rights are. Thanks Ill call the council tomorrow and ask. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 7Apr 07, 2009 8:23 pm You will find that in Queensland, zero lot boundary setbacks that are compliant with all regulations (ie. they do not form part of a siting variation) DO NOT require consultation with the neighbours. Re: Zero Lot Lines???? Help 8Apr 07, 2009 8:30 pm Melly 250mm to the boundary (OMP) - Sunshine Coast Regional Council. my site plan says as much ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Zero Lot Lines???? Help 9Apr 07, 2009 8:32 pm also check the developer plans - they should also show the approved building envelope for the block ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Zero Lot Lines???? Help 10Apr 07, 2009 10:24 pm serge44 Melly 250mm to the boundary (OMP) - Sunshine Coast Regional Council. my site plan says as much Awesome!!!! thanks Serge Id been scouring the BCA book to see if they mentioned something to no avail . the 250mm.... that would be to allow for the downpipes huh?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 11Apr 09, 2009 3:42 pm Well, I called the council and they said that they neighbours went through a private certifier. I called the certifier and he said there are no regulations that state they need to consult us about the colour of the wall. And i would be stuck with what they picked. But I should just approach the owner to see if they would agree to allow my input. Surely I would have some say seeing as it is the side facing my block and forming part of my fence. OMG!! What if they like bright pink Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 12Apr 09, 2009 3:46 pm So do they not even have to ask if its ok to take down your fence They just get to go ahead and take it down and you have no say...what if you had a pet that needed to be kept in.....I don't understand.....I am glad we have some sort of guidelines here. I would now go and approach your neighbours and just mention to them that you are happy to have a brick wall form part of your fence but you were just wondering what the plan was. Are they planning on reinstating your existing fence.? Re: Zero Lot Lines???? Help 13Apr 09, 2009 5:35 pm gweluphome So do they not even have to ask if its ok to take down your fence They just get to go ahead and take it down and you have no say...what if you had a pet that needed to be kept in.....I don't understand.....I am glad we have some sort of guidelines here. I would now go and approach your neighbours and just mention to them that you are happy to have a brick wall form part of your fence but you were just wondering what the plan was. Are they planning on reinstating your existing fence.? we dont have an existing fence.( lucky i spose ) We have just started building in a new estate too. Im happy to have the wall. Im just worried about the colour and the impact it will have visually on my house. I will have to talk to the builder. I just cant believe there are no regulations about that sort of thing Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 14Apr 09, 2009 10:41 pm Melly, the estate covenent will cover colours and the like so gaudy should be out. That said you have no say whatsoever in the colour of their house. But you can put a fence up on the boundary line and as a common boundary they should contribute. if you do fence it they are entitled to perform maintenance on the wall. if there's no fence how many times will the kids bounce a dirty basketball or soccer ball against it? and they they'd have to clean it if they wanted to maintain it or put up a fence ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Zero Lot Lines???? Help 15Apr 10, 2009 12:35 am Serge Not all estates have covenants. As mentioned earlier, there is no requirement to consult adjoining owners if zero lot boundary setbacks are done in accordance with the Queensland Development Code. The only time consultation is required is when the setback is triggered by an application for a siting variation, which only trigger in limited instances. Re: Zero Lot Lines???? Help 16Apr 10, 2009 9:44 am Our estate does have a covenant but it is not enforced as we dont need to get covenant approval before building.Its more of a guideline. and it does not mention anything about colour Ill just have a chat to the builder Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Zero Lot Lines???? Help 17Apr 10, 2009 9:49 am HomeReview Serge Not all estates have covenants. true - but I know which estate Melly is building in ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Zero Lot Lines???? Help 18Apr 10, 2009 10:26 am If you don't like the colour of the bricks you can paint them - it's on your side of the fence line... just like with some wooden fences, some neighbours paint them. This is a pretty common thing to have the garage on the fenceline 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Zero Lot Lines???? Help 19Apr 10, 2009 11:44 am If you paint the zero lot wall you are intefering with someone else property. The walls does not form the boundary line, rather it just happens to be 150mm to 250mm inside the adjoining owners land. Encouraging someone to paint SOMEONE ELSE'S PROPERTY is rubbish. Re: Zero Lot Lines???? Help 20Apr 10, 2009 12:28 pm Yeah I wouldnt just go ahead and paint their wall. I think that would make them pretty mad Im just going to chat to the builder to see what they were going to do colour wise, whether he would accept my input, and if not. whether there would be enought room to put a fence up right alongside their garage even if the fence is slightly inside my own land. that way if i dont like the colour it wont matter. I think that is the best option ATM Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4863 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10039 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4747 |
