Browse Forums Building A New House 1 Apr 02, 2009 5:08 pm Hi Everyone, well ive been quite busy for months planning and drawing on CAD, and i have a meeting with a designer next week and i am ready for some constructive criticism. ill agree its quite a large house with a big footprint, i havent done a good job on the top floor all the rooms are too big and wasteful. our simple wishlist for the house was, 1x bdrm downstairs next to the study, kids bedrooms upstairs and away from noise. a large cinema room also used for gaming with a designated server room to hide all the computers away. and last but not least a designated spa room attached to laundry. house is going to be constructed from Insulated Concrete Form (ICF's) hence wall width is 218mm, after my meeting with an architect i will most probably change the internal wall width to the thinner blocks. please feel free to add comments as i am ready to make changes, sorry for the ******* pics, punch home suite dosent support export floorplan picture! -NathanBOTH0309.pngfront elevation.jpgLOWER0309.png Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 2Apr 02, 2009 7:58 pm Yes it is big!!! And excellent effort at drawing it. Things I would change if it were my house -entrance to master walks straight into robe - beautiful big room - must be better use of space -upstairs bathroom - so much lost space for three doorways -cinema room next to a kids bedroom? I suppose it depends on the age of the kids -your bedroom is under the cinema - might be a bit noisy -pantry looks a little thin - lack of flow from pantry back into kitchen -when your guests leave the spa do you want them to walk through the laundry to have a shower or go to the toilet -closing the lounge off seems to make the space downstairs look disjointed - this is probably me as I'm a big fan of open plan -maybe move the bedrooms upstairs to the front of the house and the cinema to the rear Ideas - probably not helpful at all. It does seem awfully big!! Best of luck Fi has moved in!! Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 3Apr 02, 2009 9:17 pm Hi, good work with the first draft. I agree with the comments that 'Brittany' has made and also add a couple of other points to consider. Re your worry about the size of the place, you need to measure up sizes of rooms you or friends/family have that you would be comfortable with and check that with what you have allowed on this plan. Most of the rooms are fairly generous and you may find with moving some areas around you can trim quite a bit off it. Only you know what room you really need and would be happy with. I would look at changing the kitchen/meals area as I would prefer them to be a little closer together as they don't seem to flow. All three areas, kitchen, meals and lounge all seem to be quite separate areas but from the type of rooms you are putting into the home you seem to be going to entertain alot but might find someone doing prep work in the kitchen might be a little left out of things. One of the other things I notice is that all the rooms are quite generous sizes and yet the lounge which is the only living room on the ground floor isn't all that big. Not sure what ages the kids are but perhaps the theatre room should be downstairs and not tucked away upstairs which appears to be a kids domain. The other thing relating to kids is the bathroom upstairs doesn't appear to have a bath in it which is fine if the kids are older and only use a shower. But, if they are older do they really need double basins as I would imagine they would prefer to have private use of the bathroom?? Last thing, if the kids are older and the theatre room is going to be more for their use than your own, I would definitely be trying to relocate it away from over the top of your bedroom. Even if you disagree with all our suggestions at least it helps clarify what is important for you. Good luck with the plans and let us know what you eventually decide on!! Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 4Apr 02, 2009 9:23 pm yes thankyou brittany, as mentioned i am going to send the plans to the designer simply to cut the house down! its just too big! ill be vacuming for weeks! yes the master entrance is a bit weird, ive tried to think ways around it. but i dont want the foot of the bed to goto the door; its bad for chi or something yeah? cinema room- next to kids, was kinda hoping the BIR would hide most of the noise. perhaps building out of concrete+foam+soundstop to help, the real test would be see if it stops bass signals. not too sure on what sort of size needed for the pantry, sorta guessed that one! yeah the boss wanted to go open plan for the loungeroom, i sorta put it there in case they needed it for load bearing, as its quite a large span. it will prolly go to keep the flow and as much light in the kitchen as possible; might just have to replace the wall with pillars. spa room- was going to put the powderoom and laundry side by side, it 'might' work ill give it a try the top floor does definatly need to be redesigned, i liked the idea of both bedrooms having access to the bathroom separating them at the same time, north light coming from the LHS top of the property to utilize sun in the rumpus room, almost thought of going skillian roof thanks for the ideas so far! keep them coming guys -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 5Apr 02, 2009 9:29 pm Well done at drawing that.... you have much more talent than I certainly do First thing that I would change is your master bedroom. I don't know about you but walk in robes can tend to get a bit messy. I think if you had the robe along the right wall then you could still put your bed in font. Your house does look very big but the downstairs is very 'boxed' in. I think it needs a bit more of a flow to it. Like Brittany I also like open plan areas though. I also think the little hallway that you have between the rumpus and the cinema room (the other side of the store room) is wasted space. Samantha Building the Leabrook by Statesman at Freeling My Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=15237 We are now in our house!! Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 6Apr 03, 2009 11:46 am klscomps I would look at changing the kitchen/meals area as I would prefer them to be a little closer together as they don't seem to flow. One of the other things I notice is that all the rooms are quite generous sizes i would of liked to have the meals in the lounge area, i am working on removing that lounge wall and replacing it with a pillar to support the structure above. from my estimates and from what we are living in atm this would be a huge increase of size, our master bedroom atm is 2.4x4.2 and its differcult in the least to get the queen bed in! together without a robe! so i guess a good minimum size for a room would be 3.5x3.5 with a built in robe. as you really just need room for a bed and perhaps a desk. kids arent born as yet, we are w0rking on that but plan to live in this house for 20yrs+ as my wife and i have always moved alot with being in the navy. not planing on having double sinks that was just an idea of space; the boss does want a bath even though we have a room for a spa. sammy_sj I also think the little hallway that you have between the rumpus and the cinema room (the other side of the store room) is wasted space. yes i will look into moving the master bedroom around, see if the robe can be done better. we are using concrete floors for the front section of the house to keep the noise out from the cinema; i put it there as its the room that will prolly get used the least and does not require natural light. for the entrance/hallway i was going to get a price on this "hidden wall section" as to hide all the important gear away in the event of a robbery or just a feature see below thanks for all the comments guys as always please keep them coming, i am going to do some more drawing tonight and make some changes, its defiantly hard just changing 1 wall in a 2 storey house as it effects the room above or below for structural support and plumbing. -Nathan60457-1596-il-verticalartisans-com-vertical-stamped-concrete-concrete-door_1984.jpg Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 8Apr 19, 2010 5:12 pm lol secret door ..love it Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 9Apr 20, 2010 8:48 am Hi Firefox, Good to see your plans are progressing along quite nicely! I take it from reading your post that you intend to use ICF for internal walls as well?? I think it will be a very expensive exercise for little benefit. External walls – no problems, but for internal walls I think is a little overkill (aside from the HT, as you get acoustic insulation from ICF). Of all the ICF builds that I have seen (over 20 of them) all bar one used standard timber wall frames. So have you finalised your plans yet? Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 10Apr 20, 2010 8:58 am Great job drawing the plans looks good im sure it will all come together. Be sure to post up the final plans. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 11Apr 25, 2010 10:42 pm Could you add another room on the top level? Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 13Apr 26, 2010 3:37 pm jessie87 Could you add another room on the top level? another floor! i think ill need another 150k for that! 71monaro this was what i came up with on my home pc, we have since gone to a designer and they finished off the rest, i will post up the completed drawings up here when i get home. there are 4 quotes we got originally ranging from 4-9k we went for the 7k option and were amazed at how quickly they made changes and helped us with our council approval. currently we are stuck with council about a set back issue and are looking for another block to suit this house or another plan we found with our builder. 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 14Apr 26, 2010 5:52 pm Where abouts are you building? So you are going for a 2 storey house not a single? Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 15Apr 26, 2010 5:59 pm well we have been looking for over 6 months now for another block of land or suitable house to fit this on, after 8 auctions and 4x offers rejected we are getting a little tired of waiting! so pending on the block we will buy it will decide weather or not we build our dream home or just a standard house with fairmonts/dechellis (for now) http://concretemcmansion.blogspot.com/ plans are there if anyone is interested how they turned out 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: [PLAN] 4x Brdm, 2x Storey, ICF formwork 16Apr 26, 2010 6:12 pm quickly made a screen dump of one of our final floor plans http://www.users.on.net/~firefox/Plans/ ... 090729.jpg our designer: http://www.aspexdesigners.com.au/ recommended for speed and quality of work 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5160 Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3235 1 4588 |
