Browse Forums Building A New House 1 Apr 01, 2009 5:46 pm I am building a Santorini26 (M3tricon) in Mernda Villages. My lot happens to be on the corner and I have to do something in the corner treatment. My builder has suggested me to have a pergola built on the corner. Are there any other ideas for the corner treatment (other than pergola). Has anyone been building or has built Santorini from M3tricon? Regards, abdul Re: Corner Treatment Ideas 2Apr 01, 2009 6:39 pm There are lots of options, but it depends on the facade. Some double storey homes with balconies at the front have a false balcony added to the side. I've seen pergolas on both single and double storeys, and they can look really good if they're done well. If the facade has a gable, parapet wall, or some other distinctive feature, that might be able to be repeated in the side elevation. There's a single storey home near us that has feature columns on both the front and side elevations - they've used stack stone, but you could do something similar with a rendered finish. Have a drive around the Stockland estates and see what other people have done on corner blocks - you're sure to pick up some ideas. Re: Corner Treatment Ideas 4Apr 01, 2009 7:17 pm we have a corner block and only had to add a couple of windows and render... we asked PD to do the minimum and see what we could get away with... can never hurt... the company you are building with should be able to steer you in the right direction Sharon & Paul ********************* Creating Youngs Castle Heywood 29 in Craigieburn http://youngscastle.blogspot.com/ 4 14289 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 4784 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6150 |
