Browse Forums Building A New House 1 Mar 17, 2007 5:09 pm Hi,
I have decided I would like to split my block of land in 2 and demolish the existing home and build 2 new ones. The block is about 900m2 The problem is I have no idea where to start or if I would even be allowed to do this. Has anyone got experience subdividing? Is that the right term to use? Anyone know any builders / kit home companies that do this sort of thing? Look forward to hearing from anyone. First Timer Re: Subdividing and building 2Mar 17, 2007 9:47 pm Hi First Timer - I'm no expert in this area, however your first step would be your local council. You will need planning permission from them in order to subdivide.
I'm sure others here can add more in terms of next steps, but it would be a good place to start! Cheers Perry Re: Subdividing and building 3Mar 17, 2007 10:47 pm Thanks Perry, I have had a read of your web log and best of luck with your build. It's great to read about other peoples experience. Thanks for the advice. I will head off to the local council on Monday morning to see what's involved. Subdivision 4Mar 21, 2007 9:59 am Hi first timer,
I couldn't help but notice these posts. I run a company that may be able to point you in the right direction. If you would like to talk feel free to give me a call to discuss your options. We operate in greater Melbourne only but i'm happy to discuss regardless. You can visit: www.donahomes.com.au & get to me via the contact us page. Best of luck, Dom You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17113 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20197 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10223 |
