Browse Forums Building A New House Re: Split level 201Oct 28, 2010 10:13 am Hi Funksoul, Your block and plans look really nice. I can imagine you are going to get some nice elevated views from your upstairs lounge room and deck. We used ECS sandstone look-alike retaining wall blocks on our property. They look pretty good and are quite a bit cheaper than the boral ones. They lock together pretty easily so you may be able to DIY. How high are your retaining walls going to be? Mick Re: Split level 202Oct 28, 2010 3:29 pm Hi Funksoul, Wow fantastic views, you are going to get some great breezes through your house. Don't cut corners on the retaining its going to be the foundations block for the whole yard. Good Luck Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Move your linen into laundry and access laundry from your present linen space 1 8007 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6584 |
