We have just found out that we need to get a lot survey before construction will start on our house in Northwest sydney.
can anyone recommend a good/quick/reasonably priced surveyor?
Don't you love spending money on these things!!
Browse Forums Building A New House 1 Mar 23, 2009 4:16 pm We have just found out that we need to get a lot survey before construction will start on our house in Northwest sydney. can anyone recommend a good/quick/reasonably priced surveyor? Don't you love spending money on these things!! Re: Lot pegout/survey - anyone know a good surveyor in NW Sy 3Sep 29, 2013 6:27 am ebanster bump on this. For the possible problem with the neighbour property, go to serviceseeking.com.au and you should be able to find someone. Just post a job describing what you want. You should end up with a few quotes. There are generally feedback ratings as well. If there is an issue you need to check with council on what any recourse might be. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Lot pegout/survey - anyone know a good surveyor in NW Sy 4Sep 30, 2013 10:55 am Hi the mont, Just make sure you actually do need a re-survey as some builders simply say they can't find the (already existing) survey pegs simply because they are just covered by a bit of dirt/grass. What most people don't know is that there are 2 sets of survey pegs - the ones which stick up out of the ground and other (more accurate) ones which are buried in the ground - all you can see of those ones when you uncover them is a wooden square (around 3 centimetres square) with the lot numbers on the top of it. TBH the in ground survey pegs that I've seen would be very difficult to remove but easy enough to cover. If you're in a new(ish) estate go and have a dig around where the survey pegs are meant to be - you may just save yourself around $1,000 I am building in claymore NSW and this is shown in the building envelope plan. … 0 9970 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223465 ask the surveyor for clarification would be the logical approach 1 20115 |
