Browse Forums Building A New House Re: Which will give me a better finish - flushed or rolled morta 2Mar 23, 2009 1:13 pm Depends on your bricks and what look you are going for. I personally prefer fluch mortar, but it dowsn't look great with all bricks, i.e. tumbled edged. Have you decided n your brick? Usually the manufacturer can recommend the mortar finish that suits the brick best. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Which will give me a better finish - flushed or rolled morta 3Mar 23, 2009 1:54 pm Hi Joles, This is the colour brick I want http://www.pghclay.com.au/Bricks/Defaul ... ItemId=145 It's from PGH and the colour is called Chiara. I can't find any recommendation on which morta finish to use. Can you help? Karma - what goes around comes around sooner or later...... Re: Which will give me a better finish - flushed or rolled morta 4Mar 23, 2009 2:01 pm They are very nice bricks. If it was me I'd be going with off-white flush mortar. What other colours are you having? Windows, roof, etc? I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Which will give me a better finish - flushed or rolled morta 5Mar 23, 2009 2:05 pm Hi, After looking at your bricks I would go with the flush finish. With off white mortar. It will almost give it a rendered look!! What colour will your roof be?? tiles, colourbond?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Which will give me a better finish - flushed or rolled morta 6Mar 23, 2009 2:09 pm Awww....rendered look. Perfect! Ok I will go for flushed morta then. I am still deciding between black or grey roof tiles, white or surfmist windows.......any recommendation? I am absolutely in love with this forum. I was so upset when it was down for maitenance on the weekend....... Karma - what goes around comes around sooner or later...... Re: Which will give me a better finish - flushed or rolled morta 7Mar 23, 2009 2:13 pm You might be hard pressed to get Surfmist windows. It's not a standard colour with most companies. This is what I'd go with, white windows, Surfmist fascia, Monument guttering and downpipes and black/charcoal roof. The off-white mortar will look great with white wndows. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Which will give me a better finish - flushed or rolled morta 8Mar 23, 2009 2:15 pm I need to do some research on "monument". Not sure what colour that is. Do you have a link for the colour? Karma - what goes around comes around sooner or later...... Re: Which will give me a better finish - flushed or rolled morta 9Mar 23, 2009 2:18 pm PnSdreams Awww....rendered look. Perfect! Ok I will go for flushed morta then. I am still deciding between black or grey roof tiles, white or surfmist windows.......any recommendation? I am absolutely in love with this forum. I was so upset when it was down for maitenance on the weekend....... I think grey could look quite stunning . Gun Metal through Boral?? could be quite nice. Depends on the overall look you are going for would you go with the flat profile or shaped roof tiles. Keep in mind the flat profile is usually more expensive, Well it was through ours anyway!! . Ebony (Black) would be quite striking whereas they grey will be more subtle. There is a downloadable brochure through boral http://www.boral.com.au/Brochures/order ... mpany=Roof Tiles I love surfmist!!! It would look good with either Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Which will give me a better finish - flushed or rolled morta 10Mar 23, 2009 2:20 pm PnSdreams I need to do some research on "monument". Not sure what colour that is. Do you have a link for the colour? Monument is a colourbond colour, very dark true charcoal. Will go great with the roof colours you like. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Which will give me a better finish - flushed or rolled morta 11Mar 23, 2009 2:20 pm PnSdreams I need to do some research on "monument". Not sure what colour that is. Do you have a link for the colour? you can use this colour visualiser to add i the diff colours http://colorbond.autech.com.au/onlinevi ... esidential Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Which will give me a better finish - flushed or rolled morta 12Mar 23, 2009 2:30 pm I think I will go for black roof tiles, surfmist fascias, gutters & downpipes to achieve a stunning look! Or should I go for monument fascias & gutters, surfmist downpipes? Too many choices! Karma - what goes around comes around sooner or later...... brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7575 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 817 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 |
