Browse Forums Building A New House 1 Mar 23, 2009 12:42 pm I want to build a simple 10m x 1.2m high brick front fence. I am required to obtain engineer details in order to apply for construction certificate. I got a quote from the people my builder uses who did for my house. The quote came back $550! Such a simple fence and it is so expensive!!! Is this even a reasonable price for such job? I want to get some more quotes. Should I just look up "civil engineers" and they are generally the qualified people for this?? Any advice is appreciated!! Building Clarendon Brighton - Done and moved in Sept 2009 Re: Engineer details for a simple brick front fence? 2Mar 23, 2009 1:36 pm check with your council. I know in victoria if you are building a fence 1.2m or lower for bricks and 1.5m or lower for wooden fence then you don't even need council approvals. alternatively, just look online for a typical engineer for fences and tell the you'll be building it to these specifications. I just used the ones my builder did for the retaining wall and it went through without problems. ---->Some say that a recession is when your neighbour loses his/her job while a depression is when you lose yours!<----- Re: Engineer details for a simple brick front fence? 3Mar 23, 2009 2:08 pm smeagol check with your council. I know in victoria if you are building a fence 1.2m or lower for bricks and 1.5m or lower for wooden fence then you don't even need council approvals. alternatively, just look online for a typical engineer for fences and tell the you'll be building it to these specifications. I just used the ones my builder did for the retaining wall and it went through without problems. It is correct that, for my council, for my 1.2m high fence, I shouldn't need a DA and hence not needing a construction certificate. However, I made a very very stupid mistake . I made some changes to my landscape plan and I needed to lodge a section 96 modification to my original DA. Among the changes, I added this brick fence that was not in the original DA. I was not aware of the complication involved in building this fence. Now that the modified DA is approved, I have to amend the construction certificate to include this fence and therefore needing the engineer details. Now that I know what's involved, I should not have added the fence in the section 96 and instead apply for CDC separately This is such a simple fence. I believe the cost of building the fence is just around $3k. Now, to amend the CC, engineer details, inspection of the footing, I am adding an extra $1k to it!!! Building Clarendon Brighton - Done and moved in Sept 2009 Re: Engineer details for a simple brick front fence? 4Mar 23, 2009 2:52 pm ahhh the price of honesty mate.... if it was me i'd just update the plans and leave the fence out and see what they say.... or perhaps just call it out that its 1.2m and does not require specific engineering requirements and assure them what ever is put there complies with BCA requirements....and hope that common sense kicks in... ---->Some say that a recession is when your neighbour loses his/her job while a depression is when you lose yours!<----- Re: Engineer details for a simple brick front fence? 5Mar 23, 2009 3:03 pm Unfortunately, I have spoken to my certifier and these are the list of things he requires me to do in order to certify to get the final certificate. He won't even certify if the fence is not there. Yes indeed, price for honesty!! Building Clarendon Brighton - Done and moved in Sept 2009 Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 8211 3 5191 The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work. You might… 7 8026 |
