Browse Forums Building A New House 1 Mar 20, 2009 12:05 pm Hi,
Was wondering if someone can reccommend when I should get an independent inspection done throughout the building process. Slab Stage?? Frame Stage??? I think the builder gets their own people out at slab stage but nothing at frame stage?? I would think the frame stage is very important How much do they usually cost? Does the SS have to be there at the time or should I even tell them?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Independent Inspection- When should I get one?? 2Mar 20, 2009 12:09 pm I would say, depends on the structure...
Conc floor? Single or multilevel? Contract to lockup? Re: Independent Inspection- When should I get one?? 3Mar 20, 2009 12:16 pm Its a single story house, concrete wafflepod slab , timber frame, concrete tile roof
They allow 260days in the contract but it seems to be moving much faster. site scrape last week and pipes laid. Told slab will be tuesday and frame on 05/04. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Independent Inspection- When should I get one?? 4Mar 20, 2009 12:16 pm I think most people said that Pre-plaster is an important stage for inspection.. some also do pre-handover.. I have done one for frame/slab as well
You need to tell your SS that you have an independent inspector, so that he can let you know the expected completion time for the work (e.g. frame completion) and you can then organise your inspector to do the work.. i never be onsite with my inspector except for the pre-handover And recommendation. Big Kev of course, he is good Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: Independent Inspection- When should I get one?? 5Mar 20, 2009 12:45 pm all of the above...
ask that they cure the slab (atleast a week) Floor coverings are? If tiled/slate ask for NO curing agent be applied. ie concure or other wax sprays. Best flood and pond if poss ...also, you get to see the low areas discuss your bathroom tile height and allow a setdown so the bathroom doesn't have a trip zone at entry Re: Independent Inspection- When should I get one?? 6Mar 20, 2009 3:18 pm onc_artisan all of the above... ask that they cure the slab (atleast a week) Floor coverings are? If tiled/slate ask for NO curing agent be applied. ie concure or other wax sprays. Best flood and pond if poss ...also, you get to see the low areas discuss your bathroom tile height and allow a setdown so the bathroom doesn't have a trip zone at entry They are laying the slab on tuesday then we get the frame on the 05/04 so that should be enough time as long as the weather is good. Thanks for letting me know about the curing agent, I hadnt heard of that I havent even thought about a set down. As they already have the slab plan would it be too late to change that?? I'll have to ask the SS. What do inspectors usually look for at Slab stage.?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Independent Inspection- When should I get one?? 7Mar 20, 2009 4:12 pm Your council, should be checking the footings and mesh detail,
normally are there just before the pour if they want to. Set down is for the granos to workout it should be on the plans... are you having tiles in your wet areas? The setdown should be tile thickness plus tile adhesive + 40mm at the door jamm (middle of frame) it is just a measurement plus the falls. IMHO Re: Independent Inspection- When should I get one?? 8Mar 22, 2009 8:05 pm If you can only afford one inspection, my advice is the pre plaster one. We used Kevin from New Home Inspections for a pre plaster inspection - he found several issues with our home, one in particular which could have potentially caused major problems in the future if not addressed - and once the plaster is on, you would never know about it. Re: Independent Inspection- When should I get one?? 9Mar 22, 2009 8:12 pm kevin from www.newhomeinspections.com.au recommends two inspections (pre-plaster and pre-handover) for single storey homes. I think he recommends one more for double storey??? but not sure what stage. Agree with oztish though; if you can only afford one go for pre-plaster. So many things can get covered up never to be known of again after plaster! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Independent Inspection- When should I get one?? 10Mar 23, 2009 9:59 am donuts So many things can get covered up never to be known of again after plaster! Thats true i think I will get one at frame/pre plaster and then completion. Has anyone is queensland used Les Wildman?? Is he good??? Thanks guys!!! Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81883 It is true that a builder can ignore your independent inspection report as it is not part of the contractual arrangement but that is stupid because he cannot avoid fixing… 9 46854 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98678 |
