Browse Forums Building A New House 1 Mar 17, 2009 9:00 pm Have any of you got a data/Internet/IT point from your builder? May I ask what exactly you got from your builder? i. CAT-5 cable with a RJ-45 wall plate ii. Telephone line with a RJ-11 wall plate or ii. Telephone line with a RJ-45 wall plate I ordered one each for all my bedrooms… upon inspection I realized electrician has used a telephone like cable (4 internal wires) whereas I was expecting him to use a network cable instead (8 internal wire CAT-5 cable) When I asked the builder (Orb*t) to correct the error they defended (as always the case) saying what they mean by data/Internet/IT point is in fact a telephone line. I checked this with a 3rd party certified electrician & he disagrees with builder and said CAT-5 is what he’d use to provide a data/Internet/IT Point. Re: Electrical Technical Question - Data/Internet/IT Point 2Mar 17, 2009 9:03 pm sorry to nitpick but it should be Cat5e....
and eaither way Cat5E can be used for all the above just not 2pair cable should only be used for telephones/ telstra incoming. if they have done the ******* then yeah sick a lawer onto them and demand it be chnaged over now at their cost yet one more of the risks not hiring a propper data guy to do the job... I've encounted alot of sparky stuff ups... even being so new to my trade... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Electrical Technical Question - Data/Internet/IT Point 3Mar 18, 2009 10:08 am i. CAT-5 cable with a RJ-45 wall plate
ii. Telephone line with a RJ-11 wall plate or iii. Telephone line with a RJ-45 wall plate i. Should definetly be data cable... But you should specify a 8 pin RJ45 ii. & iii. Will be 2 pair... It can be Cat5, but for sure the network guy will put int 2 pair... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20678 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13867 |
