Browse Forums Building A New House Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2741Aug 18, 2014 9:26 pm Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2742Aug 19, 2014 8:15 am macky1012 Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? Trust me, you'd surprise how much rocks are under Aurora, just go around the construction sites you'll find out. IMO fixing site cost will give you peace of mind. You should flip through the pages in this thread to see how much more people were paying for their site cost without fixing it in the past. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2743Aug 19, 2014 8:29 am I understand that the site costs vary after soil test, but How much is approximate site cost I shall consider buidling in Aurora Estate ? I discussed with Burbank and they are fixing site cost approximate 20k as my block has 1.07m fall.[/quote] Is that 20k based off the final soil test, I doubt they will give u the correct site cost amount untill they get their final soil test results. If its just a quote from the sales consultant it doesnt count for anything. A Lot of variables effect site costs eg. Soil type, fill amount, compaction report, rock etc. Im building across the road in Eucalypt and my site costs were 27k, thats with no rock being hit or piers required[/quote] I will see if I can manage to put "subject to soil test" in section 32, but I highly doubt Aurora developer would be agreed to do so apart from "subject to finance". Can you recommend any soil tester and how much roughly it will cost ? Thanks Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2744Aug 19, 2014 8:42 am macky1012 Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? I am holding a land at stage 25 as well (Lot 2507), which lot number are you buying ? As i have discussed with various builders, so far Burbank is giving you fixed site cost and free rock removals. They are currently going through many promotions, go and have a chat. It will be worth to give a shot. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2745Aug 19, 2014 9:40 am whocares macky1012 Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? I am holding a land at stage 25 as well (Lot 2507), which lot number are you buying ? As i have discussed with various builders, so far Burbank is giving you fixed site cost and free rock removals. They are currently going through many promotions, go and have a chat. It will be worth to give a shot. Just ensure you read the T&C carefully, Looking at http://www.burbank.com.au/docs/website/ ... eCosts.pdf Unless your site is absolutely 100% perfect for construction (which i doubt any bit of land in aurora would be) your costs will be above what they are quoting. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2746Aug 19, 2014 11:07 am sogg Just ensure you read the T&C carefully, Looking at http://www.burbank.com.au/docs/website/ ... eCosts.pdf Unless your site is absolutely 100% perfect for construction (which i doubt any bit of land in aurora would be) your costs will be above what they are quoting. Thanks sogg for the info. I do realise that buidling house in 'North' does cost you extra money on site costs, which is a big pain. 'West' does not have that much site costs, but don't really comfortable living in that end. After gone through almost every estate in North, Aurora is the only one have a potential plan for development in future despite too many building restrictions. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2748Aug 20, 2014 6:47 pm aurorafrog macky1012 Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? Trust me, you'd surprise how much rocks are under Aurora, just go around the construction sites you'll find out. IMO fixing site cost will give you peace of mind. You should flip through the pages in this thread to see how much more people were paying for their site cost without fixing it in the past. Hi Aurorafrog.. I have Port3r quoting me at 30k, simm0nds is around 15k, and carlisl3 as 25k.. these are just estimates so i am not sure it would go up or down. pretty steep just for site cost i believe. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2749Aug 20, 2014 6:51 pm whocares macky1012 Hi guys. I will be putting my 5% deposit for a land on release 25 in aurora. And i am on the same scenario here.. As i was going around, they were quoting from 15k to 30k site cost (which i reckon is a high). I was discussing with aurora regarding adding the clause "subject to soil test", but they said cant do i as the site is not yet accessible. So i am not sure if i am going to fix the site cost or not if ever i proceed. I have less than 1m fall on the land (not sure how much fall on the construction area). Based on the guys that have already built around aurora area, did you end up fixing your site cost? Or how much did your site cost ended up? I am holding a land at stage 25 as well (Lot 2507), which lot number are you buying ? As i have discussed with various builders, so far Burbank is giving you fixed site cost and free rock removals. They are currently going through many promotions, go and have a chat. It will be worth to give a shot. I think we are almost on the same boat whocares... We are looking to lock up 2530.. I am not getting much positive feedback on burbnk..had a couple of friends who built with them. I will talk to them again soon to get their beef during constructing with burbnk... Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2750Aug 20, 2014 6:52 pm whocares I understand that the site costs vary after soil test, but How much is approximate site cost I shall consider buidling in Aurora Estate ? I discussed with Burbank and they are fixing site cost approximate 20k as my block has 1.07m fall. Is that 20k based off the final soil test, I doubt they will give u the correct site cost amount untill they get their final soil test results. If its just a quote from the sales consultant it doesnt count for anything. A Lot of variables effect site costs eg. Soil type, fill amount, compaction report, rock etc. Im building across the road in Eucalypt and my site costs were 27k, thats with no rock being hit or piers required[/quote] I will see if I can manage to put "subject to soil test" in section 32, but I highly doubt Aurora developer would be agreed to do so apart from "subject to finance". Can you recommend any soil tester and how much roughly it will cost ? Thanks[/quote] i already asked for the "Subject to soil test", and aurora told me that they cant because the site is not yet accessible as of the moment. so in my case, i think i just have to bite the bullet. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2751Aug 20, 2014 6:54 pm whocares Hi All, Does a conveyancer is essential before settling the land ?? We have recently purchased a land in South east Mel., and we decided to do through Slater & Gordon conveyancer. I would strongly suggest and recommend them as well. We have gone around and seek couple of quotes, and then approached S&G and they offered 5% price beat guarantee on written quote, so in the end a good name and a alright pricing helped me. If you want a detailed pricing details, i am also happy to share the same... But with all legal Tc & Cs in your 100+ pages of land contract, I would not risk it for few bucks to go without proper review through lawyer / Conveyancer please!!! 27.08.13 Building Contract 09.07.14 Site Start 24.07.14 Base / Slab 28.07.14 Frame 27.08.14 Lockup 15.09.14 Fixout 25.11.14 Settlement Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2752Aug 21, 2014 8:21 am macky1012 We are looking to lock up 2530.. I am not getting much positive feedback on burbnk..had a couple of friends who built with them. I will talk to them again soon to get their beef during constructing with burbnk... I built with Burbnk, they are all right. We had site supervisor changed half way as the first one was an awful person. But the second one was pretty good at what he does. In fact, most of the big builders are similar. Don't expect you will cruise through the building processing, it'll be stressful if you are a person pay attention to details. One thing IMO you must do is to hire an independent building inspector who has the knowledge of building standards. He can spot lots of things you won't see and the builder will have to fix almost everything from his report because the builder needs to comply to the standards. The one I used is http://www.newhomeinspections.com.au/ Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2753Aug 21, 2014 8:29 am macky1012 Hi Aurorafrog.. I have Port3r quoting me at 30k, simm0nds is around 15k, and carlisl3 as 25k.. these are just estimates so i am not sure it would go up or down. pretty steep just for site cost i believe. Not sure what you compare with in terms of 'steep'. My slab required piers, It's H class, site drop around 1.5 meter, required cut and fill. I saw tons of rocks were dig out from my land as it's like literally a rock carpet under 50cm of the soil. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2754Aug 21, 2014 6:46 pm nnsha1 whocares Hi All, Does a conveyancer is essential before settling the land ?? We have recently purchased a land in South east Mel., and we decided to do through Slater & Gordon conveyancer. I would strongly suggest and recommend them as well. We have gone around and seek couple of quotes, and then approached S&G and they offered 5% price beat guarantee on written quote, so in the end a good name and a alright pricing helped me. If you want a detailed pricing details, i am also happy to share the same... But with all legal Tc & Cs in your 100+ pages of land contract, I would not risk it for few bucks to go without proper review through lawyer / Conveyancer please!!! Could you please inbox me pricing details asap. I would see if they do the best pricing for me. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2755Aug 21, 2014 7:13 pm whocares nnsha1 whocares Hi All, Does a conveyancer is essential before settling the land ?? We have recently purchased a land in South east Mel., and we decided to do through Slater & Gordon conveyancer. I would strongly suggest and recommend them as well. We have gone around and seek couple of quotes, and then approached S&G and they offered 5% price beat guarantee on written quote, so in the end a good name and a alright pricing helped me. If you want a detailed pricing details, i am also happy to share the same... But with all legal Tc & Cs in your 100+ pages of land contract, I would not risk it for few bucks to go without proper review through lawyer / Conveyancer please!!! Could you please inbox me pricing details asap. I would see if they do the best pricing for me. Just replied you via PM. 27.08.13 Building Contract 09.07.14 Site Start 24.07.14 Base / Slab 28.07.14 Frame 27.08.14 Lockup 15.09.14 Fixout 25.11.14 Settlement Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2756Aug 23, 2014 8:13 pm aurorafrog macky1012 We are looking to lock up 2530.. I am not getting much positive feedback on burbnk..had a couple of friends who built with them. I will talk to them again soon to get their beef during constructing with burbnk... I built with Burbnk, they are all right. We had site supervisor changed half way as the first one was an awful person. But the second one was pretty good at what he does. In fact, most of the big builders are similar. Don't expect you will cruise through the building processing, it'll be stressful if you are a person pay attention to details. One thing IMO you must do is to hire an independent building inspector who has the knowledge of building standards. He can spot lots of things you won't see and the builder will have to fix almost everything from his report because the builder needs to comply to the standards. The one I used is http://www.newhomeinspections.com.au/ Yeah. A friend also mentioned that an Independent inspector is a must! And i believe in builders, it also depends on the tradies and site supervisors. so maybe my friend did not get the better of the lot. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2757Aug 23, 2014 8:21 pm aurorafrog macky1012 Hi Aurorafrog.. I have Port3r quoting me at 30k, simm0nds is around 15k, and carlisl3 as 25k.. these are just estimates so i am not sure it would go up or down. pretty steep just for site cost i believe. Not sure what you compare with in terms of 'steep'. My slab required piers, It's H class, site drop around 1.5 meter, required cut and fill. I saw tons of rocks were dig out from my land as it's like literally a rock carpet under 50cm of the soil. nah. just mentioning that the price is pretty "Steep or expensive". I reckon i have less that 1 meter fall, so hopefully all good. but still the quote is within the range of 22k-30k (and subject to soil test). I was thinking, if they fix the site cost at 30k (after soil test), could i just negotiate it not to be fixed? I think that after the soil test, their estimate is from the Max (being the Estimate) or lower. So if they are fixing it at 30K, they have an idea that it wont be more than that... - I belive they wont be underestimating the site cost after the souil test is done. What do you think? How about the bushfire levy? that is pretty expensive as well (around 5k). how do we know if we need to pay this levy? Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2758Aug 24, 2014 1:51 pm macky1012 How about the bushfire levy? that is pretty expensive as well (around 5k). how do we know if we need to pay this levy? Hi macky1012, you can go to this link to check if your property falls within a bushfire zone: http://services.land.vic.gov.au/maps/bushfire.jsp You can search by lot number. The legend will show you the shading that determines the bushfire zone. Even if only a tiny portion of your block appears in the zone, you'll be up for the charges associated with meeting the bushfire protection. The bushfire zone gets reviewed from time to time so worth coming back to the map every now and then to see if your home is no longer in the zone. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2759Aug 24, 2014 3:22 pm Jasdan macky1012 How about the bushfire levy? that is pretty expensive as well (around 5k). how do we know if we need to pay this levy? Hi macky1012, you can go to this link to check if your property falls within a bushfire zone: http://services.land.vic.gov.au/maps/bushfire.jsp You can search by lot number. The legend will show you the shading that determines the bushfire zone. Even if only a tiny portion of your block appears in the zone, you'll be up for the charges associated with meeting the bushfire protection. The bushfire zone gets reviewed from time to time so worth coming back to the map every now and then to see if your home is no longer in the zone. Hi Jasdan. Yeah, the guys from aurora told me to check this website from time to time. And unfortunately, we are still under bushfire zone. So i am hoping that it gets re-zoned before we apply for the permits. Re: LYNDARUM/AURORA/SUMMERHILL ESTATES: Epping, Victoria 2760Aug 24, 2014 3:29 pm hi nnsha. can you also send me some pricing details for the conveyancing? still looking for one, and i need to forward the details next week to aurora. thanks heaps! The setback from the kerb is 4m. It is council land to provide an area for services like sewer main, gas mains, water mains, underground power or poles for overhead power,… 4 2395 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20889 |
