Browse Forums Building A New House 1 Mar 14, 2007 7:25 pm I am building a new house and was just wondering if anyone wanted to recommend a business that they went with for this stage of the bulding process? Re: Steel frame in Adelaide. Whom did you go with? 2Mar 16, 2007 3:44 pm I'd be interested in this topic as well because we also want to build a steel frame home in Adelaide. Builders so far that I know who build steel frame are:
Format Cavalier Nu-Steel Weaks Peacock Group McCracken I have friends who are building with Format and they are suppose to have a very good reputation in the building industry. A senior planner in one of the councils also said they are one of the better builders. Re: Steel frame in Adelaide. Whom did you go with? 3Mar 23, 2007 10:38 am This link maybe of interest to you http://www.nash.asn.au/ Re: Steel frame in Adelaide. Whom did you go with? 5Apr 03, 2007 10:34 am We have a two storey hybrid (long story ![]() ![]() Re: Steel frame in Adelaide. Whom did you go with? 7Apr 04, 2007 3:42 pm Our builder is the Hot Property Group, but I don't think they build for the public anymore (I think they only do renovations and land development now).
Looks like there's a couple of "tri-steel" companies? Try this one: http://www.tristeelframing.com.au/ Because our roof pitch is ~45 degrees, no other steel framer would attempt it (beyond the specifications of steel they said). Tri steel arranged to do the bottom storey in steel and the top in timber. We're quite happy with how it turned out. I'll see if I can dig up a photo.... Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 1686 ![]() Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 1461 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 2883 |
