Browse Forums Building A New House 1 Mar 15, 2009 2:17 pm Howdy
i have seen corniceless rooms before. I have heard the cornice is to cover up gaps and to allow movemant. I agree with the gap reason , since it can be hard to measure gyproc pieces/lengths and the cut it exactly to an imperfect square ceiling. But i dont agree with the movement scinario as wouldnt the cornice just crack anyway if the walls/ceiling/slab shiffted a little? I really like no cornices. I dont want to pay for Cornices, yet i have heard builders pay more for corniceless homes. Does it really cost that much more to do corniceless ceilings , considering the cornice would cost 0$ versus the time to put in the tape and some more joint goo , and then more sanding? Any one with experience of this? Noremac Re: corniceless rooms, i want them , i dont want to pay for them 3Mar 15, 2009 5:45 pm When they say that the cornice conceals the gap between the wall and ceiling plaster they don't mean a gap of millimeters. The gap is centimeters wide between chewed off, crookedly cut plaster. Lots of space for movement Once the cornicing is on it looks neat as a pin and you would never know the shambles it conceals.
I imagine there is a great deal more effort, accuracy and craftsmanship that goes into making a square set plaster wall. Anything that takes more time and effort creates more expense Re: corniceless rooms, i want them , i dont want to pay for them 4Mar 15, 2009 6:55 pm We're having a very varied mix of medium and large cornices and square set. Even in one room, if you have coffered ceilings with cornices in the centre section it leaves a lot of square set joints where the bulkheads meet the walls.
Anyway, watching the plasterers do the square set is very revealing. They add a metal right angle instead of the tape they use at the junction of walls as this apparently helps prevent movement cracks. I've been able to appreciate that it involves a great deal more time and effort than leaving a great big gap and slapping a bit of cornice over it So I can understand why square set is more expensive than standard paper covered cornices. but it's cheaper than the larger, more elaborate plaster cornices. Cheers zeke Re: corniceless rooms, i want them , i dont want to pay for them 5Mar 15, 2009 7:44 pm We have square set cornices in our unit. Can't tell you how much it costs since we bought it built. I can understand that it cost more, but as others have said, you're saving on material so should recoup some of the costs.
I think it looks great and have specified square set cornices in our upcoming build. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: corniceless rooms, i want them , i dont want to pay for them 6Mar 15, 2009 9:17 pm Hi there
We've almost completed our build and opted for square set cornice in all living areas - it cost us an additional $300 = well worth it and cheap if you ask me. We didn't bother with square set for the bedrooms, bathrooms, hallway etc though. We have a recessed ceiling in the entry and we wanted that look to flow right through the living areas. I watched the plastered do his thing and it did take a lot longer, but the result is superb! Cheers Michelle Building in remote, regional Vic We have roof, frame, walls, plumbing, electrical....but no bricks! Re: corniceless rooms, i want them , i dont want to pay for them 7Mar 15, 2009 9:46 pm wow thats really cheap. we only wanted it to our main hallway and the builder wanted to charge us $1600. It was area area of 6m x 2m!! Re: corniceless rooms, i want them , i dont want to pay for them 8Mar 15, 2009 9:56 pm Our entire downstairs is squareset and people comment on it all the time!
We paid extra (forget how much) but it looks awesome (IMHO) Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20432 I would be wary. Is you site demilished but nothing else done? Sounds like liquidity problems to me. Our builder did the same. Got hundreds of thousands of dollars of… 2 15413 Sounds like rubbish to me. Ask for the contamination report which I doubt they have. If it's part of a normal subdivision it would have had a contamination report done… 9 5662 |
