Browse Forums Building A New House 1 Mar 14, 2009 8:15 pm As we want our WHOLE house (approximately 24 squares of living area and the top of the garage) to be rendered on the outside, if possible in two shades of cream or grey, we are looking at cheaper alternatives.
Has anyone got any experience with Hebel or a product that is similar? I have heard that it has some great eco friendly properties and is an excellent insulator. I have also seen an advertisment for the product in a M3con catelogue - so if anyone building with them could give us some insight it would be GREATLY appreciated!!! Does it work out cheaper then buying the cheapest bricks possible then having them rendered? Have people choce to go with Hebel Panels or Bricks? Any reflection or photos or ANYTHING on this product and its finish would be GREAT Re: Hebel Vs Brick Render 3Mar 14, 2009 9:09 pm Aimeh.
We are cladding our new home with Exin, a lightweight material, which will be rendered all way round. Our builder says it is an excellent product and is about the same price as a brick home with only front rendered. Google it to find out more. Juzzo two with sauce please Re: Hebel Vs Brick Render 4Mar 14, 2009 9:58 pm Sounds gret Juzzo - There site it under construstion right now but Ill be sure to take a look! Have you begun construction? If you happened to have a blog or some pics I would be really interested to see the progress of your new home built from this product. Re: Hebel Vs Brick Render 5Mar 15, 2009 8:18 am Aimeh There site it under construstion right now but Ill be sure to take a look! The Exin site used to be there, so they must be reworking it... Exin is distributed by RMAX, and there is some information on it here, CSIRO report here, and technical info here. (No, I don't work for any of the companies, it's just that we are currently looking at Exin as an option for external cladding, with the same SA builder as Juzzo). This is 100% true. You can not hang anything on steel frames. very frustrating 8 5346 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5871 1 6601 |
